Flat spot at 3500 RPM's
- RIP: cookie
Re: Flat spot at 3500 RPM's
A little MMO in the gas tank can temporarily make the slides work better ....
Possible diagnosis ....
Thanks, all, for the advice. Sounds like the carbs will be coming off sometime soon...
Did a plug chop, but it was inconclusive. While I was out of town, the kid took her out for an 80 mile run around, and the plugs yet again ended up black and sooty (except #3 again). Pulled the carbs, the started with whiskerfish's vacuum test. I'm not sure if maybe my shop vac just doesn't have enough power, but could only get #3 slide to move, and only twice out of numerous attempts. All the others were non - responsive. Turned the rack upside down and did a vacuum test on the fuel line, and it held 20 PSI for several minutes, so I think the float needles are good. Pulled the carb tops and polished up the slides extra thoroughly, then pulled the bowls and reset the floats (which were close, but not great). Weather permitting, they'll go back on tomorrow, and we'll see what we have...
While they are still off try the shop vac thing again now that they are cleaner. Make sure you are opening the throttle while holding the hose on the runner. If they are working right it is easy to detect. Also you can usually hear a slight click as the slide bottoms out when you close the throttle.
I use regular hot soap and water and a small piece of worn scotch brite to clean inside the brass liner of the cap. Then after I blow it dry I do a test of the smoothness in my hands.
Thanks for the tips, again, whiskerfish! The slides were definitely sticking. They got a soapy water bath and a scotch-brite scrub this morning, followed by a brake cleaner rinse. Once installed, they popped up and down like grease on a hot griddle! Got the carbs installed and the bike ready to ride just in time for a torrential downpour to put a damper on things! GRRRRR! We're now sitting on the porch watching the radar...
- sparkyrasmus
I've been following this. Hope the ideas work out well, Keep us informed!
1983 GL1100 Standard- raised from the dead and back to organ donor status
And the newest acquisition, 1979 XS 650F to be a sidecar tug.
Shagged a quick ride in between showers. NO FLAT SPOT! WHOOP, WHOOP! Gonna revisit the idle and sync, and take her for a real ride!
Awesome!!!
Well, between my step-son and I, we've logged about 300 mostly highway miles with varied results. The flat spot is still noticeable at times, and sometimes almost as bad as when we started. I can't make it happen in the driveway. It doesn't happen (or is hardly noticeable) with a full tank; half a tank or less, rough roads, and/or lots of curves, it becomes more obvious. It doesn't seem to change much if I switch to reserve, either.
Possibilities I'm pondering include partially clogged fuel lines inside the tank (it was professionally cleaned and lined several years ago), too small a diameter fuel lines (new, 1/4 inch, IIRC, along with a flushable fuel filter), a questionable fuel pump, or some combination thereof.
One more thing to throw in the mix... The compression hasn't changed at all. She's still running right around 90 PSI for all four cylinders. The plugs look better, but still have a fluffy carbon build-up around the outside and gray/ white electrodes. I was expecting (hoping) for some signs of improvement, but maybe it's to soon...
Jugs one and three...
These plugs have about 200 miles on them. Carbs are at factory settings, and have been synced. Would the low compression be a contributing factor to this? Should I be concerned about it yet, or just keep riding it? I really don't want to make things worse...
Jugs two and four...
Jugs two and four...These plugs have about 200 miles on them. Carbs are at factory settings, and have been synced. Would the low compression be a contributing factor to this? Should I be concerned about it yet, or just keep riding it? I really don't want to make things worse...
pm sent
- OCR
Plugs appear to be indicating lean burn and #4 is not firing at all or at least long enough to wash off any residue at low rpm.
You need to do "plug chops" to find exactly where this is occurring so that it can be fixed.
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
76LTD
77Goldwing
Thanks for the response. I've done three chops, and all were inconclusive. I haven't gotten any noticeable sooty build-up on any rides less than 10 miles of mostly highway. When I pull any plug wire, there's a noticeable change, although it's not as significant on #4. Reading Randakk's tips, factory settings on these is typically lean to begin with, and I've been running a K&N air filter, which I've read can also cause a lean condition. The quandary is 'black sooty' typically means rich, yet the electrodes read lean.OCR wrote:Plugs appear to be indicating lean burn and #4 is not firing at all or at least long enough to wash off any residue at low rpm.
Right now the cylinders are soaking to see if the rings will loosen up. I'm going to pull the carbs (again), as well as order a stock air filter. If the compression didn't show any change, a leak - down test will be on the to - do list...
So I just read back through this thread to get an idea where I left off messing with these carbs and just rode the bike. Now that I'm going through them yet again, there are more pieces to the puzzle.
A. One of the carb tops was damaged at some point after the last rebuild. Makes me wonder if any were leaking before.
B. The air cut valve diaphragm was installed improperly, likely making it inoperable, but in what position, who knows.
C. The jet towers show significant corrosion. I pretty much ignored this issue, thinking that the o-rings would still seal properly. Upon disassembly, I found several of the jet o-rings to be deformed or damaged. This is probably the worst one. If you look closely at the inside you can see a darker ring where the o-ring sits when installed. The area looks quite porous...
Can these be saved?
Can these be saved?
- flyin900
That is definitely an issue with the corrosion on there that will not seal correctly. Is it causing your issue; well only fixing that and trying the repair will tell the tale.
I would look for a replacement set of carbs, or individual units if you can find a cost effective set available. As the guy who repairs cooling fins on cylinders I would try to rebuild those towers with an epoxy that is gas proof, if another set isn't available.
I will be time consuming and tedious work, which is right in my wheelhouse as a challenge.
Current Bikes:
- 3 Replies
- 1276 Views
Last post by Hukmut
- 679 Views
Last post by Bloodhound
- 13 Replies
- 782 Views
Last post by Steven UK
- 13 Replies
- 632 Views
Last post by Cakey
- 7 Replies
- 404 Views
Last post by chewy999
