Squishy Brake Lever
- Mashmash
Squishy Brake Lever
Hello Friends,
Just a quick question. What are the possible causes of a squishy brake lever? I just bled the front brakes on my 1981 GL1100 and am still experiencing a very squishy lever and little stopping power.
Thanks
Thanks
1981 GL1100
Re: Squishy Brake Lever
Typically, there is still air trapped in the lines somewhere. The one line into a splitter into two lines setup can be difficult to bleed. It helps to 'prime' the master cylinder before attaching the line as well. One way to help the air move up to the master cylinder is to labs the biker on the side stand with the front wheel turned so that the master cylinder is at its highest point, tie back the lever about 3/4 of its travel, then let it sit. Another method is to use a vibrating sander on the lines and/ or splitter. I invested in a vacuum pump, which makes the task much easier and faster.
- Mashmash
Thanks so much for the advice. After some additional research I saw some videos of people using a large syringe full of brake fluid to force the brake fluid in from the bleeder valve, while simultaneously removing it from the res. Any thoughts on that method?Track T 2411 wrote:Typically, there is still air trapped in the lines somewhere. The one line into a splitter into two lines setup can be difficult to bleed. It helps to 'prime' the master cylinder before attaching the line as well. One way to help the air move up to the master cylinder is to labs the biker on the side stand with the front wheel turned so that the master cylinder is at its highest point, tie back the lever about 3/4 of its travel, then let it sit. Another method is to use a vibrating sander on the lines and/ or splitter. I invested in a vacuum pump, which makes the task much easier and faster.
1981 GL1100
Mashmash wrote: Thanks so much for the advice. After some additional research I saw some videos of people using a large syringe full of brake fluid to force the brake fluid in from the bleeder valve, while simultaneously removing it from the res. Any thoughts on that method?
Called reverse bleeding. They sell tools to do exactly that too. It does work very well.
- scootsx2
Depending on how the caliper is mounted, the bleeder valve might not be on top resulting in a trapped air bubble. I have this issue with the caliper mounting points on my leading link forks. My work around is to reposition the calipers during bleeding.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- Mashmash
I ordered this...robin1731 wrote:Mashmash wrote: Thanks so much for the advice. After some additional research I saw some videos of people using a large syringe full of brake fluid to force the brake fluid in from the bleeder valve, while simultaneously removing it from the res. Any thoughts on that method?
https://www.amazon.com/gp/product/B07C7 ... UTF8&psc=1
Hopefully I can get it worked out.
Thanks again for all the help fellas.
1981 GL1100
Those are great for bleeding. However, brakefluid can swell the rubber seal in them
- todd54219
Check the rubber brake lines, they might be expanding/swelling when brakes are applied.
Just thinking out loud.
Todd
Todd
1976 Yellow GL1000
1976 Yellow GL1000
wow, you do not need that big of a syringe. a 3ml will work. Yes the brake fluid ruins the syringe, so it is a one and done throw away after doing itCYBORG wrote:Those are great for bleeding. However, brakefluid can swell the rubber seal in them
I have several large ones, and they are also great for changing fork fluid via the drain hole. Drain the old fluid, and inject the new. No need to remove the springs, Or forks
- RIP: cookie
I have an endless supply ....
I have Gord to thank for mine. I just rebuilt a set of forks for my 1200. Never had a spring out. Not having to deal with the springs makes it an easy job
it helps to have a sourceRAT wrote:I have an endless supply ....
- AussieGold
This is what i do.
Drain the old fluid.
Tie the brake lever back a smidgeon.
DRIP FEED the new fluid in. Very very slowly. As in DRIP FEED.
As the new fluid fills the calipers and lines it will fill without air pockets.
Never had a problem. M.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
If you can't get the last bit of air out by bleeding try turning the handlebars so that the master cylinder is at the highest location and tying the lever to the handlegrip overnight. This sometimes allow the air bubble to find its own way up & out.
- 193 Views
Last post by Rat
