GL1200: Do I need to connect 4th gear and overdrive signal to Ignition?
- Lead Member
Hi, I tried to search and Google it but could not find anything.
Sorry for my bad english.
I am building a streetscrambler from a Gl1200 Interstate 85 and I want to reduce/simplefy the electrics and the 4:h gear and OD is connected to the Ignition, I assume it has to do with timing advancment? I wont have any lights that indicate OD and I cant just short it out. What to do?
Best regards Patrik from Sweden.
Re: GL1200: Do I need to connect 4th gear and overdrive signal to Ignition?
The gear selector light on the 1200 is controlled by a switch under the front cover. Same switch that shows the neutral light. Has no effect on ignition timing
- Lead Member
That do I need to do with the two cables from gear select sensor into Ignition control module?CYBORG wrote:The gear selector light on the 1200 is controlled by a switch under the front cover. Same switch that shows the neutral light. Has no effect on ignition timing
- Lead Member
- Lead Member
Or can I just the two wires? Now i realize that the OD cable shorts to ground when the bike is in 5:th gear.... :D
I could be wrong, because it has happened before-lol- but I believe timing is advanced more in fourth and fifth gear. There are the wires which feed info as well as a vacuum signal. You could ride without it and probably not notice. With it intact you probably get a few for mpg .
I lived in Karlstad for 35 years.
Looks like you are correct. As you say might be a MPG issue, and that makes sense to me. But I don't really worry about MPG , so I don't have a reference. That being said, I have a C5 system on my 78 and I control the Ign curve, four choices, which are not really to much difference between them, but is helpful when using the nitros, or steep hills.
- 77Gowing
Wulf, your English is fine.
Good luck on your project.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
- flyin900
The module is so small that I would keep it intact and leave it in the circuit along with the vacuum hoses. If you don't have the OD lights that won't be an issue, yet removing the circuit completely may cause more issues than just gas mileage.
Current Bikes:
- Lead Member
Will keep it, I just lost it then I read the schematic, did not realize that the cables just shorts to ground then you shift to 4 and 5.flyin900 wrote:The module is so small that I would keep it intact and leave it in the circuit along with the vacuum hoses. If you don't have the OD lights that won't be an issue, yet removing the circuit completely may cause more issues than just gas mileage.
did you all notice the manual used "very" instead of "Vary"
...signals the ignition control unit to electronically VERY ignition timing.....
Yeah, who was the copy editor...rcmatt007 wrote:did you all notice the manual used "very" instead of "Vary"
- 77Gowing
Is it very well or vary well?
Yeah but I have to give it to Honda, their FSM was written fairly well.
77Gowing
77Gowing
- 410 Views
Last post by Shadowjack
- 0 Replies
- 337 Views
Last post by sphen
- 14 Replies
- 274 Views
Last post by CYBORG
- 0 Replies
- 129 Views
Last post by Mike-C
