1976 GL1000 HEADLIGHT UPGRADE?
- hybrid455
I spent some time searching the archives but the most recent post I found was 2016 for a what was apparently a Vetter equipped machine. My sulfur yellow clone project is nearing completion and I have been thinking about added visibility with a headlight upgrade. My bike has been restored to naked status and there is very little room in the bucket due to the fistful of wires behind the bulb. It does have a H-4 type lens and bulb. I do not believe this is original but I had one. I think the original Honda sealed beam was very shallow in depth compared to the H-4 lens or a 7" Automotive application. The H-4 lens was difficult to get into the bucket due to all the wire connects. I think the automotive application I have read about would prove nearly impossible to fit in the original bucket without finding some more room in the bucket.
Does anyone know of a proven upgrade for a projector LED or HID set up? I like the look of the Halos, does anyone have personal experience with a mod like this? Does anyone have a solution for the absence of available space in an OEM bucket?
Projects
77 GL1000
1976 GL1000A Sulfur Yellow Clone - complete
1976 GL1000 LTD - complete
77 GL1000
Re: 1976 GL1000 HEADLIGHT UPGRADE?
this is relevant to my interest as I want to do the same thing with my 76.
I haven't measured it yet to see if it would be a direct swap(keep forgetting to) but I put an LED light in my wife's 2002 shadow and there was plenty of room for it in the bucket.
- wog
I've got one of these https://www.cyclegear.com/parts/speedme ... ersion-kit installed in a '78 (plastic bucket). Love the brightness, but did need to cut out the rear of the bucket and notch for the cable...
Not sure how it would be cutting the steel earlier buckets and it does need the ventilation (has a mini fan that hums).
Good price at $50, I think I paid $90-$100.
Might buy another now for my "current" build.
- hybrid455
I also found this link from a post that Whiskerfish did in 2016.wog wrote:I've got one of these https://www.cyclegear.com/parts/speedme ... ersion-kit installed in a '78 (plastic bucket). Love the brightness, but did need to cut out the rear of the bucket and notch for the cable...
https://www.xenondepot.com/H4-Xtreme-LE ... -h4-mc.htm
It looks similar to the one you posted. I wondered how long the cable was. It might be nice to try and stow away the ballast under the shelter cover.
Projects
77 GL1000
77 GL1000
Can't suggest a sealed beam,etc,but this Emgo copy of a Lucas headlight shell has room in it. I had no stock mounts,and made these to clear the '77 steering lock and guages.
Lucas copy on home- built mounts.
- IMG_20181025_093913961.jpg (392.35 KiB) Viewed 291 times
- LuckyEddie
I put a newer style Yamaha H4 in my 76, clear glass with parabolic reflectors in the back.Works great.
Here is a pic of the box with numbers, no longer made, check eBay. A pic of headlight on the bike. And of course, the headlight runs through a relay. That on it's own makes a huge difference.
This baby really lights up the night.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
According to cyclemax this LED headlight will fit all gl1000’s and it is great quality and performance for less than 60 bucks. I have no personal experience with it.
- 9E5D67BD-B4B3-4F3D-B2C0-209B063E7567.png (791.52 KiB) Viewed 239 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- hybrid455
That's a great look. I like it! How deep does the lens extend into the bucket?LuckyEddie wrote:I put a newer style Yamaha H4 in my 76, clear glass with parabolic reflectors in the back.Works great.
Projects
77 GL1000
77 GL1000
- LuckyEddie
Normal dimensions.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Why/how does the relay make a big difference?LuckyEddie wrote:I put a newer style Yamaha H4 in my 76, clear glass with parabolic reflectors in the back.Works great.
78 GL1000 Original Owner 131k
- LuckyEddie
It takes the electrical load off of the starter switch as that is the supply route for the headlight.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Thanks.LuckyEddie wrote:It takes the electrical load off of the starter switch as that is the supply route for the headlight.
- hybrid455
If I understand it correctly due to the design of the factory circuit there is a voltage drop before power finally finds is way to the headlight bulb. Adding a fused power supply directly from the battery while utilizing factory wiring to control a high and low beam pair of relays allows a more stable and slightly higher voltage to the headlight.SnoBrdr wrote: Why/how does the relay make a big difference?
Projects
77 GL1000
77 GL1000
- LuckyEddie
I used just one relay by tapping into the circuit before the high/low beam switch on each of my wings.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
- 14 Replies
- 1045 Views
Last post by Whiskerfish
- 7 Replies
- 514 Views
Last post by desertrefugee
