gl12000 into a 1000 frame 76 carbs
- pierce
- My Album: pierce
Re: gl12000 into a 1000 frame 76 carbs
cyborg, perhaps you can help me with wiring. not sure if the manual would help, but a diagram of the wiring would suffice.
Did you just cut the connector off and connect the wires to wherever the diagram said? I am surprised that no one can point me to a thread in which someone details the wiring. I guess that means I am in somewhat unfamiliar territory. 86 wiring diagram anyone?
1976 GL1000
1978 Gl1000
1978 Gl1000
Just tried sending a diagram to your email. Lmk if you can see it.
Can't help you with pictures or links. Computers are not my thing. and I did mine many years ago. but it really is plug and play.pierce wrote:cyborg, perhaps you can help me with wiring. not sure if the manual would help, but a diagram of the wiring would suffice.
- pierce
- My Album: pierce
Got the diagram! Looks deceptively straightforward.
I'll go ahead and purchase a cdi igniter. Looks like two wires go to gear selector, then 4 to the coils, then the vacuum line to the carbs.
1976 GL1000
1978 Gl1000
1978 Gl1000
like I said. Pretty straight forward. You will love it
Following.
- pierce
- My Album: pierce
So, here we go. Hopefully someone can help me out.
There are 10 wires.
From top to bottom
(First Connector)
1 - Green = ground
2 - Blue/Yellow stripe
3 - Yellow/Blue stripe
4 - Black/White stripe
(Second Connector)
5 - Black/Blue stripe
6 - Black/Blue stripe
7 - Blue
8 - White/Blue stripe
9 - White/Yellow stripe
10. - Yellow
First Connector - goes to coils
1 = Ground
2 = Coil Spark plug 4
3 = Coil Spark plug 2
4 = Coil Spark plug 1 + 3
Second Connector
5 - Turn into Green/Orange stripe
6 - Turns into Red/White stripe
7 = Pulse Generator 3 (Front of Engine)
8 = Pulse Generator 4
9 = Pulse Generator 1
10 = Pulse Generator 2
5 + 6 go to gear shift sensor
5 = OD (5th Gear)
6 = 4th gear
Does this look correct?
There are 10 wires.
From top to bottom
(First Connector)
1 - Green = ground
(Second Connector)
7 - Blue
10. - Yellow
1 = Ground
Second Connector
5 = OD (5th Gear)
6 = 4th gear
1976 GL1000
1978 Gl1000
1978 Gl1000
The OEM fuel pump relay triggers off the blue/yellow and the electronic tach off the yellow/blue. Or vice-versa, doesn't matter.
- pierce
- My Album: pierce
Honestly, I don't think that I have the fuel pump relay, and positive that I don't have the electronic tachometer. I do have the oem fuel pump, which I will use, but everything else including all wiring is from a 76.
1976 GL1000
1978 Gl1000
1978 Gl1000
- pierce
- My Album: pierce
Question, engines about to go in, however does anyone know what these are?
Closeup
Closeup
1976 GL1000
1978 Gl1000
1978 Gl1000
I have an 85 1200 Apsencade that I haven't worked on yet so I'm not sure but I noticed in one of my pics on my phone that there is something mounted on that hole and the intake manifold tube to the carb sits on top of that. I looked in the parts diagram and can see the hole but not what goes there.pierce wrote:Question, engines about to go in, however does anyone know what these are?
1975 Honda Goldwing GL1000 (café project, started Oct 2018)
1978 Honda CB400T Hawk II (son's project)
1980 Honda CB750C Café
1986 Honda Goldwing GL1200 stock dresser
Kinda off topic... what is the reason you are wanting to put a 1200 in a 1000 frame other than the obvious? Why not build the 1200 to your liking? Seems like a popular swap
Part of the “afterburner” for the turbinator so the flux capacitor doesn’t get too hot.
To use it you need the 1200 carbs and intakes. Guys who disable it plug the hole with JB and whatever. I bought four freeze plugs close to size and used JB to seal. The hole leads down to a port in the exhaust. Each hole goes up to a collector under the base of the plenum. I never looked into what it actually does. Probably adds air to pass emissions testing??? Another option is using the tubes/hoses and plugging the plenum end.
There are o-ringed tubes which fit there.To use it you need the 1200 carbs and intakes. Guys who disable it plug the hole with JB and whatever. I bought four freeze plugs close to size and used JB to seal. The hole leads down to a port in the exhaust. Each hole goes up to a collector under the base of the plenum. I never looked into what it actually does. Probably adds air to pass emissions testing??? Another option is using the tubes/hoses and plugging the plenum end.
- pierce
- My Album: pierce
I have a 1000 frame available, no 1200 frame.brewer013 wrote:Kinda off topic... what is the reason you are wanting to put a 1200 in a 1000 frame other than the obvious? Why not build the 1200 to your liking? Seems like a popular swap
1976 GL1000
1978 Gl1000
1978 Gl1000
- pierce
- My Album: pierce
I am running 76 carbs, so would I need to do anything to those holes (really)?
ericheath wrote:Part of the “afterburner” for the turbinator so the flux capacitor doesn’t get too hot.
1976 GL1000
1978 Gl1000
1978 Gl1000
