starter?
- Sagebrush
Re: starter?
Could be the starter, how do you know that the battery is good? Might try jumping directly to the starter post with the positive lead and ground to the frame from a car battery. Should turn the starter over, make sure its in neutral and if you don't want it to start turn the kill switch to off. If it doesn't turn over then you know for sure its the starter.
- flyin900
Re: starter?
Getting the battery load tested is a good idea at a local automotive parts supplier to confirm your battery is good. These wings need a lot of cranking amps to properly turn them over. So a weak battery may still light your lights well, but not turn the bike over.
The starter may also be very dirty inside with lots of worn carbon dust causing a big current draw that can be rectified by doing a cleaning of the rear brush area and the front gears re greasing. There are tutorials in the "Shop Talk" section.
I would start with a load test on the battery first and go from there.
Current Bikes:
Re: starter?
Also clean all the battery connections. Positive and negative. On both ends.
Re: starter?
yeah, my first thought would be a poor ground connection
- Lead Member
Re: starter?
i jumped it directly from the battery with cables to ground, and it was intermittent, sometimes nothing, twice it ran, but slowly, battery tested good at autozone...just ordered one on amazon..will report on wednesday...d
Re: starter?
If battery tested good why buy another one?
- Sagebrush
Re: starter?
Sounds like the starter to me.
- salukispeed
Re: starter?
Did someone just remove the starter cable at the starter stud. It is critical that a super thin 10mm wrench be used to keep the stud from moving at all when the cable nut is removed or tightened. If allowed to turn even a little can compromise the internal soldered connection, rendering the starter useless unless repaired. . Just thinking
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Re: starter?
easy to break.... don't ask how I know
- Lead Member
Re: starter?
thanks guys, the new starter fixed it..
- salukispeed
Re: starter?
Glad You Got it fixed.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
Re: starter?
i wouldn't throw away the old one, but then, i am a bit of a hoarder.
these starters respond well to disassembly, cleaning, fresh grease and new brushes.
Re: starter?
I agree,... as long as the lug the cable attaches to isn't twisted, and the wire inside broke loose. That can be fixed, but will take more then a kit to do it.twooldwings wrote:i wouldn't throw away the old one, but then, i am a bit of a hoarder.
Re: starter?
BTW re "headlight dims when attempting to start": The Start button has 2 sets of contacts. The main contacts close when you press the button, allowing current to flow to the solenoid. The 2nd set open when you press the button, interrupting current to the headlight so that more is available for turning the starter motor.
- 10 Replies
- 514 Views
Last post by Sidecar Bob
- 10 Replies
- 1300 Views
Last post by medlinaround
- 12 Replies
- 476 Views
Last post by JOLLY
