Now we are expected to count?ericheath wrote:See post 12
1976 GL1000 Hasn't Been Started Since 1985
Re: 1976 GL1000 Hasn't Been Started Since 1985
78 GL1000 Original Owner 131k
- OCR
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
76LTD
77Goldwing
Posts are numbered under the heading
I never noticed that, forest for the trees.ericheath wrote:Posts are numbered under the heading
Thanks.
this will be fun to watch
- Graham Cracker
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- JamesPal
Good news about the engine freeing up. Have you tried to put electrical power to it yet? Check the lights, try the starter and see if it has spark? Change the oil and filter and a squirt of starter fluid? You may get a new year's surprise to go with Christmas.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- Aberdale
I'm not to that point yet. I spent last week going through the brakes (rebuilt calipers and master cylinders), and general clean up. This weekend I removed the fuel tank and carburetors. I've been cleaning carburetors all day today, soaking them in an ultrasonic cleaner filled with warm acetone. The carburetors are cleaning up nicely, and the acetone cuts the old gasoline varnish pretty quickly. The floats and needles are moving again.JamesPal wrote:Good news about the engine freeing up. Have you tried to put electrical power to it yet? Check the lights, try the starter and see if it has spark? Change the oil and filter and a squirt of starter fluid? You may get a new year's surprise to go with Christmas.
This week I'm planning on cleaning out the tank with muratic acid and putting the carburetors back together. Once the fuel system is clean, I can start putting the bike back together.
Hopefully I will get to the point of hooking up a battery mid-January.
'dale
I'd rather be lucky than good lookin'.
1970 Honda CB450
1976 Honda GL1000
1982 Honda CX500 Turbo
1981 Yamaha SR500
1972 BMW R75/5 Toaster
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
1987 Harley Davidson Tour Glide
1990 Harley Davidson Heritage Softtail
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
- JamesPal
Dale, consider oiling the carburetor throttle shaft seals after cleaning. The cleaning solution along with them being old will dry them out. This can be a source of idling problems. The seals are made of felt and are oiled in the factory. I use Liquid Wrench White Lithium aerosol while putting a vacuum on the carb body. After the carb is assembled and before attaching to the plenum. Duct tape the small end of the carb to a shop vacuum, turn it on, put your hand over the other end of the carburetor venturi and them spray the throttle shaft area when it goes through the seal.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- Aberdale
Thanks for the tip! Excellent technique to make sure the lubricant gets to the felt.JamesPal wrote:Dale, consider oiling the carburetor throttle shaft seals after cleaning.
'dale
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
- scootsx2
HIGHLY FLAMMABLE FUMESAberdale wrote: ... I've been cleaning carburetors all day today, soaking them in an ultrasonic cleaner filled with warm acetone. The carburetors are cleaning up nicely, and the acetone cuts the old gasoline varnish pretty quickly. 'dale
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
as sung by pink Floyd...
Breathe, breathe in the air
- Aberdale
Yes! Don't use it near an open flame . . .scootsx2 wrote:HIGHLY FLAMMABLE FUMESAberdale wrote: ... I've been cleaning carburetors all day today, soaking them in an ultrasonic cleaner filled with warm acetone. The carburetors are cleaning up nicely, and the acetone cuts the old gasoline varnish pretty quickly. 'dale
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
- Graham Cracker
We hate fire...
Mark
- Aberdale
It runs!
After spending the last couple weeks removing/cleaning/rebuilding components, I finally got everything back together yesterday. Today I installed a new battery and put a couple gallons of gasoline in the tank.
I cranked the motor in short bursts, but couldn't get it to fire. Checked for spark. No joy. I found a pinched wire inside the points cover, cleaned the points, and tried again. Still no run. I sprayed a little starting fluid into the air cleaner and it fired a few times. Tried it again and it took off, as long as I held the throttle partly open.
It smoked quite a bit at first, but eventually it cleared up. I imagine it was burning off all of the PB Blaster and ATF that I used to soak the cylinders loose. I adjusted the idle speed a little faster and let it run until it got up to operating temperature. It sounds pretty good! The alternator is charging. All the lights now work. The tachometer seems a bit slow, but does work.
If there wasn't 4 inches of snow in the driveway I would have taken it for a spin . . . . .
Still, all-in-all it was a good day.
'dale
'dale
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
- 40 Replies
- 2620 Views
Last post by MikeNTexas
- 4 Replies
- 502 Views
Last post by CrazyJerry
- 14 Replies
- 1509 Views
Last post by Gowing
- 65 Replies
- 5749 Views
Last post by OldRider2
