'85 1200 - Oil on my shoes
Steve81GL1100
Re: '85 1200 - Oil on my shoes
Post by Steve81GL1100 »
ericheath wrote:You don’t need to remove the cams to replace seals. It may help to loosen the cam carriers (6 bolts), but they can be tapped in. I think it’s tight going over the bumps for the pulleys so you don’t nick the seal lip. Tape them up first.
Correct. What I meant was, you don't have to completely remove a cam to replace the seal. However, the aforementioned bump can be an issue, and I think that's what damaged my first replacement seal. I picked up a new one from the dealer today, and will likely pull the cam to install it just to be extra sure I don't muck it up. 15 bucks isn't much, but it's a hassle to take it all apart again since I won't know if it leaks until it's all together and I ride it.....
-Steve-
Steve
1996 BMW R1100R
JamesPal
Post by JamesPal »
The seals for the valve covers and cam came today. I should be able to get them in this weekend. I really appreciate everyone's input. I will post the results.
'85 GL1200I
'81 GL1100 STD
'72 CB450
