Balancing Act
Balancing Act
Okay, so the tyres arrived, I bought the updated Moly 77 (grease, not paste) and basically now I'm ringing around to see who does what for how much. Then I had a chat with a mate, "why don't we do it, seems straight forward," which i have to admit, it does, until we talked about balancing... He contends that motorcycles don't need wheels balanced after a new tyre goes on, and whilst i bow to his wealth of knowledge, i found that a strange fact... So it begs the question: T or F? I've read around, like i do for every topic it seems, and there's the usual 50/50 for either community, but i'm throwing this one out to people who specifically know the bike i ride ('79 GL1000) from the inside out. To balance or not to balance...
To be honest, I'll have it done regardless for my own peace of mind and the fact that once that insurance gets paid i intend spending all the time i can seeing how these new tyres handle !
Re: Balancing Act
I ALWAYS balance my bike tires.
and, just like car tires, they need balancing periodically thru their life. The last few years I have been using dyna beads which maintain the balance thru out the life of the tire.
- tlbranth
Re: Balancing Act
Back in the 70's we didn't, to my knowledge, balance tires. Never had a problem even when I took my CB750 up to 126mph. I do balance them now, however. I bought the jig to do it and it's too easy to do so why not?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: Balancing Act
I agreetlbranth wrote:Back in the 70's we didn't, to my knowledge, balance tires. Never had a problem even when I took my CB750 up to 126mph. I do balance them now, however. I bought the jig to do it and it's too easy to do so why not?
- Zinc Member
Re: Balancing Act
I bought a wheel balancer ~30 years ago and have never regretted it. It's a fairly easy process.
Do bike tires "need" balanced? Some of the tires I've installed are close enough that I probably would have been okay without balancing. If you never go over 60mph, and are lucky to get tires that are naturally close to being in balance, you'll probably never notice the difference.
As to "DynaBeads", I'd forgotten all about them. I used them on several bikes, but never was completely convinced one way or the other as to whether they actually helped. Haven't added them to new installs for years.
TLDR - It's your life. I balance my bike tires.
82 GL1100 Standard 44k miles 83 wheels & forks
Re: Balancing Act
my vote, Yes balance them.
Re: Balancing Act
over the last 250,000+ miles and approximately 80 sets of tires (sport bikes wear them pretty quick) I have balanced nearly every set. An inexpensive static balance can be made for about $20.
I found that some tires usually did not require any weight. pilot powers come to mind. Other tires required a lot of wait to balance. Shinko for instance. I also found that on some tires the colored dot marked the heavy spot and on others it marked the light spot.
an unbalanced front tire can contribute to head shake and cupping, while an unbalanced rear tire will wear unevenly and both will last longer if properly balanced. I prefer a static balance to dynamic.
Re: Balancing Act
so what are y'all using to balance your tires?
Re: Balancing Act
Dyna beadsrcmatt007 wrote:so what are y'all using to balance your tires?
Re: Balancing Act
what I meant (beside the beads) was where did people get the tool to balance their tires
Re: Balancing Act
With Dyna beads you don't need any tools. Just put them in through the valve stem hole.rcmatt007 wrote:what I meant (beside the beads) was where did people get the tool to balance their tires
- Steve81GL1100
Re: Balancing Act
++ on the Dynabeads. They're inexpensive --less than $20 for the kit for front & rear -- and you never have to think about it again. Available directly from the mfr at www.innovativebalancing.com
Not connected to them at all, aside from buying several sets of Dynabeads...
-Steve-
-Steve-
Steve
1996 BMW R1100R
1996 BMW R1100R
Re: Balancing Act
I was skeptical in the beginning. but have used them for years. just install,...and forget about balance
- LuckyEddie
Re: Balancing Act
Harbor freight #98488. Works fine for me for many years now.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Re: Balancing Act
How do YOU determine how many beads to use?LuckyEddie wrote:Harbor freight #98488. Works fine for me for many years now.
