Stator connector stir-fried
- tlbranth
I have 3 bikes with stators. All 3 have fried the connector coming from them. I found a good alternative to the standard connector which seems to hold up well to the current. They're called Anderson Power Poles. I used the 30 amp version on all 3 bikes. Anderson insists you buy their crimping tool but I didn't. I used my regular pin crimper (takes a bit of experimenting) with good results. Here's a couple of pics of the latest casualty - my wife's 750 Shadow - and the fix. You can get powerpoles online from lots of vendors. Get extra metal bits for experimentation to get the crimp right. Don't try solder. It gets on the contact surface and buggers things up.
- IMG_2015.JPG (69.18 KiB) Viewed 718 times
- IMG_2016.JPG (76.59 KiB) Viewed 718 times
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- Rednaxs60
Re: Stator connector stir-fried
Good alternative to soldering. Lots of choice with this connector.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
Looks good. I'm using 60 amp rated gold plated connectors for RC helicopters. So far, so good.
good find and thanks for the info on the connectors. gonna have to invest in some of those.
on a side note, not trying to hijack, I have done it in the past but then I learned that soldering wires to connectors on any machinery that moves or vibrates is a bad idea and crimping (with strain relief) is the only long term solution. and yes I realize a lot of people have done it and never had issues... YMMV but... even a perfectly soldered joint from wire to connector can fail due to vibration stress. bottom line, crimps are mechanically stronger.
from what I have experienced personally, soldering in-line wire splices is perfectly acceptable. as long as one does the olde Western Union wrap splice then heat shrinks over the soldered splice with waterproof goo inside the 'shrink'.
H2G2=42
H2G2=42
I aqgree. If done.... it must be done properly
now if I could see 22 gauge wire in the first place...... I swear the print on the page is getting smaller and smaller
I use the original type. If you maintained the electrical system like you do the engine this problem doesn't occur. Maintaining connectors like that is the easiest thing you could imagine: Just unplug the connector and re-plug it every few years and while you are doing that look for any signs of corrosion and if you see green clean it out thoroughly (this is like changing the electric system's oil & filter).
If you see any signs that a wire is corroded disassemble the terminal from the connector, cut off the terminal and replace it with a fresh, new one properly crimped on (you can solder it if you aren't confident in your ability to do a good crimp but that can cause the wire to become brittle next to where it was heated and break later so a good crimp is always better). Before you insert the new terminal into the connector flush the connector out with contact cleaner and use a brush or other mechanical means to make sure that no sign of the corrosion remains.
Roger, “I swear the print on the page is getting smaller and smaller.”
On the plus side, you can’t see your wrinkles, the hair in your nose and ears. It’s all good.
- tlbranth
SC Bob. I see your point Bob but don't think electrical connectors should be a maintenance item and since the stator connector on Hondas fries so often (all of mine did), it seems a better connector for that amount of current is called for. I did put some of that goop on each blade of the Andersons before connecting them. I'm 73 so that should do it eh?
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Hmmm... All of yours fail and you don't do electrical maintenance. I do and I've never had one fail.
Anyone else see a pattern forming here?
- RIP: cookie
Bob's way is best ??
I think the biggest problem is that mostly we do not think about connections being a maintenance item, until something does not work. I guess if none of us every drove in the rain
My HD has connectors that are made to be weather tight (I don't think anything is "proof"). But even then, if you live in a humid clime, or a climate that gets really cold and then warms up.....
Is rain the worst you've got? I'm not just talking about My 'Wing that I drove to work rain or shine during the warmer halves of 18 years but the winter machines I drove to work in rain, sleet, snow (& road salt) and occasionally sunshine too, not to mention the GS400 that I drove in both summer & winter at one time.
BTW: I don't specifically set out to unplug, inspect and re-plug every electrical connection on the bike as a maintenance procedure. Some of the connections get unplugged when I am working on electrical mods (I have replaced the instruments on Eccles several times and on Mr.H. twice and replaced the handlebar switches and all of the lights on both for a start, not to mention the connections to the sidecars - yes, I am that rare guy that actually likes working on electrical stuff). That plus looking at any wiring & connectors that are near where I am working on anything else on the bike adds up to nearly everything being looked at occasionally without it becoming a big job in itself.
- tlbranth
Good point Bob. I never really considered routinely re-seating connectors. Probably a good idea under the circumstances. I still think the Honda plug is inadequate for that particular load though.Sidecar Bob wrote:Hmmm... All of yours fail and you don't do electrical maintenance. I do and I've never had one fail.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
With all the extra loads I ran on Eccles when I was commuting in all weather plus the bigger U1 battery its connector would surely have failed if the design was inadequate.
The same type of connector is used in all kinds of products that plug into your 110V power to, including stuff like 1500W heaters so surely it must be OK for a 300W alternator.
- 24 Replies
- 737 Views
Last post by EdK
- 4 Replies
- 232 Views
Last post by John Schmidt
- 8 Replies
- 383 Views
Last post by Steevensi
