Is this as nasty as I think it is?
- mensor
Embarrassing but a learning moment I think... Symptoms of fuel delivery issues led me to the decision to replace my fuel filter today (randakk’s filter and new lines seem to have done the trick for the moment) Morbid curiosity got the best of me and I cut the old one apart... see for yourself.
The filter component fell out into my hand so was def not hanging on by much of that oe glue. Looks like I’m headed for another carb cleaning next...
“I may be going to hell in a bucket, but at least I’m enjoying the ride”
'78 GL1000 “Ramblin’ Rose”
Re: Is this as nasty as I think it is?
how old was the filter? And what does the tank look like? additives in the fuel?
- mensor
Filter is 3 or 4 years old. Tank is in surprisingly good shape. Nothing real bad upstream far as I can see (had a look inside last year). Since I’ve had the bike (2013), I’ve never used any additives and run 89 non-ethenol as standard. Occasionally filled it with regular unleaded when I didn’t have the choice.
There was an issue with filters a few years ago. The fuel was eating the glue that held the element in position. That is what they would look like after it happened.
Hard to complain about a filter that last 4 years I consider them an annual tune up thing
- mensor
Yeah... not proud of keeping that one so long. Time for the carbs to come off ya think?
- flyin900
Why if the bike is running well now. Maybe pull all the drain screws out and drain the bowls to see what comes out of there. Kind of hard to get anything under them to really to catch the gas, so I usually just bunch up a wad of blue shop paper towels to catch the gas. Less contortionist than trying to fit things under there and you will catch any debris in the towels to see what is coming out of the bowls.
Current Bikes:
OEM Honda fuel filters only, from a guy that learned the hard way.
- mensor
Interesting.... I just put Randakk’s high performance filter on there with great enthusiasm. Did I make a poor choice?Don R wrote:OEM Honda fuel filters only, from a guy that learned the hard way.
you are suppose to change filters?
No those are good. the Older plastic ones like in your picture were problematic. The new one with the metal based filter element are good.mensor wrote:Interesting.... I just put Randakk’s high performance filter on there with great enthusiasm. Did I make a poor choice?Don R wrote:OEM Honda fuel filters only, from a guy that learned the hard way.
Yeah, I use aftermarket filters on everyone's bike.
I do like to use a clear filter so you can keep an eye on it.
I use glass filters with replaceable elements. Easy to see when they get dirty, and verify the fuel is getting to the carbs, if neededrobin1731 wrote:Yeah, I use aftermarket filters on everyone's bike.
- mensor
Good stuff to know... next time. Been so pleased with Randakk stuff before, I didn’t do much shopping, just grabbed his. I’ll certainly be making it a yearly habit to check up on the filter element though!CYBORG wrote:I use glass filters with replaceable elements. Easy to see when they get dirty, and verify the fuel is getting to the carbs, if neededrobin1731 wrote:Yeah, I use aftermarket filters on everyone's bike.
- mensor
Yeah apparently!rcmatt007 wrote:you are suppose to change filters?
- 12 Replies
- 282 Views
Last post by wingrider
