C5 ignition
millerdog
Re: C5 ignition
Post #46 by millerdog » Mon Aug 05, 2019 11:45 am
I think it would be very difficult to actually detect a voltage spike. It would be a millisecond event, but more than likely destroy the unit. It’s a low voltage ignition, so it probably wouldn’t take much.
Explorer
Re: C5 ignition
Post #47 by Explorer » Mon Aug 05, 2019 5:51 pm
It's taken everything that my ham-fisted installation could throw at it!
millerdog
Re: C5 ignition
Post #48 by millerdog » Mon Aug 05, 2019 8:21 pm
Explorer wrote:It's taken everything that my ham-fisted installation could throw at it!
LOLOLOL! So far, mine too!
BlueThunder
Re: C5 ignition
Post #49 by BlueThunder » Tue Aug 06, 2019 4:43 pm
millerdog wrote:I think it would be very difficult to actually detect a voltage spike. It would be a millisecond event, but more than likely destroy the unit. It’s a low voltage ignition, so it probably wouldn’t take much.
If the unit does not have voltage spike protection built in, it is a poorly designed unit.
...Brian
1977 GL1000 - Ox
1980 CB750F DOHC SS - Blue Thunder
Re: C5 ignition
Post #50 by ericheath » Wed Aug 07, 2019 8:44 am
Most electronics have built in protections up to a range. Surpass the range and poof. I’m sure PowerArc and C5 have a range.
millerdog
Re: C5 ignition
Post #51 by millerdog » Fri Aug 09, 2019 4:26 pm
Well, an update. I rewired the entire system. I have power directly from the battery, through the converter to the coils. Only 31 hundredth of a volt loss. Well within specs. I have the module getting feed from one coil, with a 25 amp automobile rocker switch on the positive wire. Cranks right up, and runs flawlessly up to 6 grand. I have tried every possible position on the maps. Still no dice. I’ve tried every plug gap that there is. Still no go. At this level in the game, I’m gonna have to consider the fact that I’ve wasted my money. Never had this problem ever, until I installed this ignition. Carbs have been unnecessarily rebuilt also. I knew it wast the carbs, as it run fine before ignition install. I’m stumped. I would call Paul, but at this point, I feel it’s pointless. No pun intended. LOL. Oh well. Live and learn I guess.
Re: C5 ignition
Post #52 by Track T 2411 » Fri Aug 09, 2019 6:41 pm
I'm curious how much one would have to change on a bike to 'test' that unit's operation. I have a good running '76 with a new Dyna ignition, coils, and plug wires. What would it take to swap in the C5 and see what happens? Just a thought...
Explorer
Re: C5 ignition
Post #53 by Explorer » Fri Aug 09, 2019 6:52 pm
You're the first really unhappy camper that I've ever heard of, on all the major forums, in fact the worst I ever heard was "it don't seem any different from what I had before".
Someone mentioned before about the rev limiter being stuck somewhere in the software?
I'd call Paul and ask him if that's possible. The C5 is no rip off.
millerdog
Re: C5 ignition
Post #54 by millerdog » Fri Aug 09, 2019 7:22 pm
I just got off the phone with Paul. Great guy! He suggested running a jumper wire directly from the battery to the coils, essentially bypassing the converter. Something about not enough amps to the coils. If that doesn’t work, he said to eliminate the converter all together. He said if I burned up a coil, he would replace it. Standup guy!
desertrefugee
Re: C5 ignition
Post #55 by desertrefugee » Fri Aug 09, 2019 8:14 pm
That seems odd. For all intents and purposes, surges and spikes won't bother the coils. It's the ignition module I'd be worried about. (Especially if I splashed 5 or 600 bucks for it). I'm surprised he's concerned about the coils...
As for the DC to DC converter, there are far simpler ways to squelch DC transients. At the most basic level, a good old fashioned zener diode can even do the trick.
'97 Valkyrie, '86 VMax Project, '79 CBX-Z, '78 GL1000, '83 Voyager Lite Project, '78 750F BIG Project, '74 750K HUGE Project
"Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence or stupidity." - Anonymous
millerdog
Re: C5 ignition
Post #56 by millerdog » Fri Aug 09, 2019 8:15 pm
Explorer wrote:You're the first really unhappy camper that I've ever heard of, on all the major forums, in fact the worst I ever heard was "it don't seem any different from what I had before".
LOL. I’m the first I’ve heard of too. Every one I’ve spoke with, or any posts I’ve ever seen on it, nobody is running a converter. Which leads me to believe that is the trouble in the equation. And, you make a good point. That’s exactly what it feels like. And sounds like too. Like it’s hit a rev limiter. Paul said worst case scenario, I can send it back, and he would check it for me, and send a video of it actually being used. Real nice guy. I’d like to have a cold one with him, and pick his brains. Very knowledgeable!
millerdog
Re: C5 ignition
Post #57 by millerdog » Fri Aug 09, 2019 8:19 pm
desertrefugee wrote:That seems odd. For all intents and purposes, surges and spikes won't bother the coils. It's the ignition module I'd be worried about. (Especially if I splashed 5 or 600 bucks for it). I'm surprised he's concerned about the coils...
I don’t think he’s that concerned about damaging the coils. It’s definitely for protection of the module. He just had me wire everything through the converter for preventative measures I think. He said it was mostly for old British bikes and tractors. Evidently the charging systems on those were not the most reliable, and prone to voltage spikes.
Re: C5 ignition
Post #58 by ericheath » Fri Aug 09, 2019 10:46 pm
I remember one or two people who felt it was overrated. Curious to see how the bypass goes.
Explorer
Re: C5 ignition
Post #59 by Explorer » Fri Aug 09, 2019 11:17 pm
Hmm! I remember those. Old Joe Lucas, Prince of darkness!!
Re: C5 ignition
Post #60 by Whiskerfish » Sat Aug 10, 2019 7:53 am
Dad's 1945 2N tractor has a "3rd" brush generator and that is how you adjust the voltage out of it. On the outside of the case you loosen up a locking screw and slide the brush up or down to tweak the output. It throws so many spikes a Digital Multi meter will not work on it. It just flat out refuses to give a reading. You have to use a analog meter to set it up. From his FB posts I know Paul does a lot of performance work with old Tractors so I "suspect" that may be where this comes from.
I have never seen anything near that on a Wing and really doubt it is an issue.
Who is online
Users browsing this forum: bagger13, gary496 and 1 guest
