To this point I've done 2 ground up rebuilds on a '75 and '76.
Partly into this '83 I discover the "points" are not on the end of the cam shaft and at the back of the engine.
Then I read they're electronic.
My question is then.........do they need setting/adjusting?
If so how?
Yeah I'll get the factory manual.........but more fun to ask for now
GL1100 Electronic Ignition
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
- JBz
Re: GL1100 Electronic Ignition
Supposedly yes . They have some kind of expoxy to keep them set. I think the service manual might be wrong on the setting . I opened mine up on the 83 when I had the engine out. After that it started knocking on a real steep grade in low gear<my driveway>. Id leave them alone next time >>>They arent really arcing tipe mechanical points but electronic gizmos tipe.. JB
- Sagebrush
Code: Select all
As sagebrush says, they don't need/can't be adjusted. Ignition maintenance consists of making sure all components are working correctly, cleaning all wire connections (and grounds), and making sure the coils, plug wires, and caps are in tip-top condition. Then ride!
- JBz
wonder where i got that information from?? . I thought I
adjusted the pulse generator. Sorry for any confusion Where is my prevogin???? JB
- chewy999
The pulse generator and the advancer unit aren't adjustable, but I think they are matched pairs. If you look at this -
https://www.cmsnl.com/honda-gl1100-gold ... LSH-OTsZ9B
there is an A, B and C for each item, and I'm sure I read somewhere that they should be the same. Not sure of the difference or how you know what you have. Maybe worth a check though.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- BlueThunder
What about the gap between the reluctor and the pickups? I don't know if that is adjustable on the GL1200s, as on other Honda models.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- 9 Replies
- 794 Views
Last post by elslimdiablo
- 4 Replies
- 796 Views
Last post by ericheath
- 25 Replies
- 587 Views
Last post by JSBail
- 19 Replies
- 1610 Views
Last post by wingrider
