I thought I liked the TourMasters on my '83 until I tried Kenda K673 Kruz tires. The Kruz front has a triangular cross section so it leans over like a narrower tire but puts more of the tire on the road when leaned.
Unfortunately, what made them handle well on 2 wheels made them really bad on 3 so I had t change to something else when I added the sidecar.
1984 GL1200 Standard rear wheel/drive issue
Re: 1984 GL1200 Standard rear wheel/drive issue
- flyin900
Yes you get what you pay for with some ocassional exceptions. While the Shinko’s are a decent tire, they are not up to the more expensive ones I have run before. I normally buy higher end tires for my bikes, yet I was finding that I usually date coded them out before I wear them out. Having MBS and rotating through every bike equally ends up with only 2-3 K per year on each bike.
I thought I would try a more economical option this time around to see if the Shinko Tourmaster 230 tires were as good as the reviews noted on the websites.
Current Bikes:
I've gone to the Shinko's for the same reason.flyin900 wrote:Yes you get what you pay for with some ocassional exceptions. While the Shinko’s are a decent tire, they are not up to the more expensive ones I have run before. I normally buy higher end tires for my bikes, yet I was finding that I usually date coded them out before I wear them out. Having MBS and rotating through every bike equally ends up with only 2-3 K per year on each bike.
- calif wingnut
- IMG_9513.JPG (147.3 KiB) Viewed 325 times
- IMG_9514.JPG (100.61 KiB) Viewed 325 times
- IMG_9515.JPG (144.4 KiB) Viewed 325 times
- 13 Replies
- 1621 Views
Last post by Rednaxs60
- 7 Replies
- 833 Views
Last post by 305@16
- 37 Replies
- 6158 Views
Last post by wmpotter399
