Resistor caps and wires
- millerdog
Does anybody know if you can use stock resistor caps with spiral core wires? Not sure if you can just screw them into the ends of the wire like solid core. Thanks y’all!!
Re: Resistor caps and wires
Would "think" so, just make sure you get a connection between the wire and the cap...
- millerdog
Thanks. I’m trying to get a new C5 ignition installed, and it calls for resistor plugs and caps, but the wire they provide is Moroso spiral core. I’ve only ever used solid core wires.
- 1 Replies
- 175 Views
Last post by C5Paul
- 13 Replies
- 645 Views
Last post by redglbx
- 11 Replies
- 302 Views
Last post by egelasi
- 6 Replies
- 279 Views
Last post by mcgovern61
