Hello all,
Foundthis ignition on a 79' GL1000 engine that was give to me for the cost of a bottle of Moscato. The only mark on it is a KV on the back. Looks something like a Charlies Place ignition but the pickups are pretty adjustible. Any ideas?
This engine also has a dipstick on the front of the engine and is plumbed into the drain plug. I'll get a picture of that later. Looks like this was in something other than a motorcycle frame, maybe a trike or something.
Ignition ID
Ignition ID
- 20190607_065935.jpg (46.64 KiB) Viewed 366 times
- 20190607_065957.jpg (59.47 KiB) Viewed 366 times
1977 GL1000, 1200 transplant, sold
1976 GL1000
1975 CB360T(in the family since new and restored)
1974 CB360
1961 T20 Tiger cub SL
1959 T20 Tiger cub S
03 Shadow Spirit 750
1976 GL1000
1974 CB360
Re: Ignition ID
That is a Dyna ignition.
Re: Ignition ID
Found a picture of a Dyna 3, looks like it plugged into an ignition module. (was curious about the size of those bullet connectors!) Thanks Robin.
1976 GL1000
1974 CB360
1976 GL1000
1974 CB360
Re: Ignition ID
The dipstick connected to to the drain plug is pretty standard for aftermarket dipstick kits.
When I added the sidecar to my 'Wing I remembered (not very fondly) having to lay across the seat with my head hanging between the bike & sidecar to see the sight glass on my previous GoldWing sidecar outfit. I was lucky enough to find a NOS drag specialties dipstick kit for mine but more recently Cyborg has made small batches of dipstick kits that attach there too.
- calif wingnut
Re: Ignition ID
You have the first generation Dyna S ignition made by KV Products. In my prime many moons ago, I use to fill out the warranty cards for all the members in my Gwrra chapter (1979 up) that I installed them on and mailed it back. I opened up my mail box one day and found a new S, a gift from the designer/owner of KV Products Ken Rodgers.
As for the pin size, we were coming home from Wing Ding 79 in AZ when my friends 78 started missing etc, one of the slightly smaller Dyna 3 male ends was arching within the oem harness point end-one crimp to make it tight, problem solved :<)
- DSC01332.JPG (98.38 KiB) Viewed 284 times
- WD79 (2).jpg (42.52 KiB) Viewed 284 times
- wd79.jpg (34.54 KiB) Viewed 284 times
- wing ding 79 adventure.jpg (47.01 KiB) Viewed 284 times
Re: Ignition ID
Thanks for all the info. The dipstick is on the crusty side but might clean up. Not sure if I'll put it to use, might look interesting on the wall. As for Dyna III. That will probably hang right next to it. Do the control boxes ever surface?
1976 GL1000
1974 CB360
1976 GL1000
1974 CB360
Re: Ignition ID
I like the pictures. What is the fairing on the second bike from the left? I thought Vetter until I enlarged it. Looks more aerodynamic.
1976 GL1000
1974 CB360
1976 GL1000
1974 CB360
- calif wingnut
Re: Ignition ID
Kimstock Voyager Fairing
- wing ding 80.JPG (153.07 KiB) Viewed 227 times
- Tridair-fairing-2.jpg (106 KiB) Viewed 227 times
- 0 Replies
- 264 Views
Last post by gltriker
- 7 Replies
- 357 Views
Last post by desertrefugee
- 42 Replies
- 1318 Views
Last post by millerdog
- 74 Replies
- 5576 Views
Last post by CYBORG
