Hi All - my 3/4 side dropped and then the 1/2 side dropped so I am looking for some power to the points. With my meter I see no power at either blue or yellow tabs at the points. Hooking up to the lower ballast terminal with ignition on and "run" on switch I see 4.2 volts. When I turn the switch to off; the voltage jumps to 11.2V. This seems odd.
I see the black/white wire on top left side of coils. How do I get access to look for power here? Pull coils?
Bike has 14K - found it in a garage and is in real good shape - no outside storage. Has been running fine.
Looking for test spots to check that power is going to points. Coils look fine and no visual items with wires etc.
thxs kenai
78 GL1000 -no power to points
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
Re: 78 GL1000 -no power to points
Scroll down to bottom of this page and you will find Similar Topics.
At least 2 down there with 3-4 points as the subject.
Cliff (74yrs )
- tlbranth
I'm assuming you have one probe on the negative battery terminal. If the points are closed, you'll get next to nothing between the points and ground. Disconnect the two bullets from the duplex w/b connector, turn on the ignition and read the voltage between the duplex connector and the negative battery post. Do the same with the ignition switch off. The kill switch should be set to "RUN". Let me know what you read.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
wire to tab was grounding out; coated with liquid tape and lined inside of points cover with plastic film used on auto paint protection
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- tlbranth
Yep. Not much room in there. Glad you got it fixed.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
- 5 Replies
- 703 Views
Last post by RoyB
- 7 Replies
- 348 Views
Last post by Whiskerfish
- 3 Replies
- 268 Views
- 8 Replies
- 295 Views
Last post by Earl43P
- 21 Replies
- 382 Views
Last post by 82aspy
