Any ideas how to stop this getting any worse...?
Psycheonabike
Post by Psycheonabike »
Small tear in seat :-?
1982 GL1100 Standard
RIP: cookie
Re: Any ideas how to stop this getting any worse...?
Very common spot for those seats to fail .... tough fix because of the flexing .... best I’ve ever managed was shoe goop covered with a piece of black duct tape .... but then my handle is Rat for a reason ....
Gord anim-cheers1
BlueThunder
Post by BlueThunder »
Or Super Glue the spot. Make sure you go beyond the rip.
...Brian
1977 GL1000 - Ox
desertrefugee
Post by desertrefugee »
You can slow it, but you cannot stop it. As Rat noted, also it may not look the way you want it to look either.
Good luck. If it’s any consolation, I have the beginnings of some stress points showing up on my rather expensive Mustang seat on the Valkyrie. Not happy about it.
scootsx2
Post by scootsx2 »
Take it to a competent auto upholstry shop.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Gowing
Post by Gowing »
Liquid rubber, works great. Been using for years. Many different kinds.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Psycheonabike
Thanks Gowing ...
pjlogue
Post by pjlogue »
You might try a piece of denim larger than the rip and tease it under the seat cover so it is flat with a good overlap into the unbroken area. Then take some black Urethane windshield setting compound and smear it under the seat cover so it bonds the denim to the underside of the seat. Wipe off the excess. That should last for some time and will reinforce the ends of the rip in the cover.
-P.
Psycheonabike
pjlogue wrote:You might try a piece of denim larger than the rip and tease it under the seat cover so it is flat with a good overlap into the unbroken area. Then take some black Urethane windshield setting compound and smear it under the seat cover so it bonds the denim to the underside of the seat. Wipe off the excess. That should last for some time and will reinforce the ends of the rip in the cover.
-P.
Thanks!! :orange
