1983 GLA wiring ??
- Rusty Probie
1983 GLA wiring ??
Got a 1983 Gl1100A , building a bobber out of it . Any reason why the wiring harness from an 82 1100 would not work on the 83? Somewhere down the line somebody has chopped the wiring harness up pretty good , even tho it was running when I bought it a year ago . I have completely restored but in the form of bobber..... xzo
- Earl43P
Re: 1983 GLA wiring ??
Two differences as I recall....82 speedo has a red or amber light for rear air pressure low, the 83 speedo uses that spot for a red light to indicate 5th gear Overdrive, using a different neutral switch under the transmission cover than the 82 (neutral only).
83 has no requirement to keep air in the rear shocks. There is a module at the rear of the bike on the 82 that drives that air shock low light. You won’t be needing that at all, so don’t worry about that loose connector.
Both years had self canceling turn signals should you like to keep that feature. Speedo has a sensor in it, along with the steering head angle sensor and an electromagnetic hammer in the left handlebar Control. I believe there is another module for that, but I can’t recall it’s location.
There’s also an onboard air compressor to decide about.
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
- 3 Replies
- 196 Views
Last post by underbuilt62x
- 8 Replies
- 520 Views
Last post by rcmatt007
- 117 Views
Last post by Sagebrush
