Page 1 of 1
Coil gone really bad!!!
Posted: Wed Jul 17, 2019 3:08 pm
by Psycheonabike
All I did was fit a CDI unit and she ran amazing. Until I took her out for a second time......?!?
- 20190717_200630.jpg (73.17 KiB) Viewed 323 times
Re: Coil gone really bad!!!
Posted: Wed Jul 24, 2019 11:37 am
by Sidecar Bob
CDI? I didn't know anyone made Capacitor Discharge Ignitions for GoldWings. In any case, your 1100's original Transistor Amplifier Ignition (TI or TAI) sould probably be far superior to most CDIs.
Posted: Wed Jul 24, 2019 2:57 pm
by Psycheonabike
Posted: Wed Jul 24, 2019 6:05 pm
by Sidecar Bob
Yeah, there are a lot of people selling stuff on eBay that haven't a clue what they actually have. These are usually the same type of seller that lists used rad hoses and timing belts...
Posted: Thu Jul 25, 2019 2:03 am
by Psycheonabike
Posted: Thu Jul 25, 2019 9:22 am
by scootsx2
That's appears to be listed as a Silverwing (GL650) part.
Posted: Thu Jul 25, 2019 10:08 am
by Sidecar Bob
Apparently they are. I've sent DSS an email about that. Calling a TI Spark unit a CDI is like calling a carrot a turnip: They are both edible roots but they are definitely not the same thing.
There is a huge difference in the way a CDI and a TI work. A CDI stores charge in a capacitor and then discharges the capacitor through the ignition coil's primary winding to produce the spark pulse. In a TI system the Spark Unit uses a uses a transistor amplifier to open and close the circuit between the coil and ground (similar to what the points do in a Kettering ignition).
In the CX/GL500/650 world the difference is very pronounced. The CDI used in CX500 models is powered and triggered by extra windings on the alternator stator with absolutely no connection to the bike's 12V system while the TI used in GL500, '81 and later CX500s and all CX/GL650 models works the same way as the system that the GL1100 has (yes, they use the exact same SU as the GL1100). Even the ignition coils are different and if you use a CDI coil on a TI bike or vise versa you will likely do harm to either the coil or the electronics.
Posted: Fri Jul 26, 2019 2:26 am
by Psycheonabike
Posted: Sat Jul 27, 2019 8:03 pm
by scootsx2
What's with this
@scoots stuff? You must have mistaken me for someone who does Twitter nonsense.
Posted: Sat Jul 27, 2019 8:08 pm
by Sidecar Bob
So they told me they called them what the Honda manual did and I informed them that neither the GL1100 FSM or the CX/GL500 FSM mentioned "CDI". I haven't heard back from them.
I don't have any confidence in DSS since the CX500 camchain guide fiasco anyway.
Posted: Sun Jul 28, 2019 1:34 am
by Psycheonabike
scootsx2 wrote:
What's with this
Just presumed this forum works the same as others. Maybe not.
#catchinup #hatehashtagstoo #heresanotherone
by Psycheonabike
Pity as they're well respected from what I recall in my ST1100 days.
Posted: Sun Jul 28, 2019 8:53 am
by 5speed
Sidecar Bob wrote:So they told me they called them what the Honda manual did and I informed them that neither the GL1100 FSM or the CX/GL500 FSM mentioned "CDI". I haven't heard back from them.
I bought a "oem style" replacement rear signal light for my 1100 from them. Looked the same but the stem wasn't even close to OEM style.
