Fuel Gauge
Psycheonabike
Fuel Gauge
Post #1 by Psycheonabike » Thu Jul 18, 2019 4:08 pm
....sometimes it works, sometimes it doesn't...mostly doesn't.
Which end should I check as there a low voltage going into the sensor at the tank...not sure what that means tho?
All advice welcomed!
1982 GL1100 Standard
BlueThunder
Re: Fuel Gauge
Post #2 by BlueThunder » Thu Jul 18, 2019 5:04 pm
Make sure your float connections are clean and tight first. Then report back and we can go from there.
...Brian
1977 GL1000 - Ox
1980 CB750F DOHC SS - Blue Thunder
Psycheonabike
Re: Fuel Gauge
Post #3 by Psycheonabike » Thu Jul 18, 2019 5:09 pm
If it helps there's no response at the dial when I remove the float etc from the tank and manually move it up and down slowly.
Re: Fuel Gauge
Post #4 by Track T 2411 » Thu Jul 18, 2019 5:32 pm
The fuel gauge uses 7 volts, and is wired through its own regulator. You can (very carefully) remove the metal cover and clean up the contacts where the float lever slides along the wire coil. Some people have had success with that. I say 'carefully' because there's a fine wire connection inside that you don't want to damage...
Psycheonabike
Re: Fuel Gauge
Post #5 by Psycheonabike » Thu Jul 18, 2019 5:53 pm
I see. I gather the regulator isn't separate from the unit and replaceable?
77Gowing
Re: Fuel Gauge
Post #6 by 77Gowing » Thu Jul 18, 2019 6:01 pm
The 7v regulator is not part of the sending unit assembly. It is mounted underneath the LH panel.
Suggest you look at the shop manual.
A wise man has many counselors, NGW is one of mine
"Get your facts first, then you can distort them as you please." :drunk Mark Twain shakehands
I believe in the Scientific Method...you screw up and then learn from it. anim-cheers1
Yes you have a right to do most anything you want, but the consequences are all your own. :oops:
It costs nothing to be nice or respectful.
Kenny 77Gowing
1942 T23 Pershing Tank, Gasoline engine/electric drive. (@ Ft. Benning)
1977 GL1000
2014 Yamaha 950 V Star (sold)
2017 Indian Scout Std w/ABS
Re: Fuel Gauge
Post #7 by Track T 2411 » Thu Jul 18, 2019 8:59 pm
77Gowing wrote:The 7v regulator is not part of the sending unit assembly. It is mounted underneath the LH panel.
Actually on the 1100's the 7v regulator is tucked under the instrument cluster...
Psycheonabike
Re: Fuel Gauge
Post #8 by Psycheonabike » Fri Jul 19, 2019 1:53 am
Track T 2411 wrote:Actually on the 1100's the 7v regulator is tucked under the instrument cluster...
There ya go....see, always worth asking eh?
Thanks man.... anim-cheers1
pidjones
Re: Fuel Gauge
Post #9 by pidjones » Fri Jul 19, 2019 8:53 am
Replacement 7 volt rgulators are available from the goldwingdocs site.
1978 GL1000 - winter project for 2020 challenge
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
Ex '75 RD400
Psycheonabike
Re: Fuel Gauge
Post #10 by Psycheonabike » Fri Jul 19, 2019 3:49 pm
Cleaned sensor with no damage to small wire. No change. Temp gauge works, down the fuel gauge have its own regulator?
Re: Fuel Gauge
Post #11 by Track T 2411 » Fri Jul 19, 2019 4:28 pm
The temp gauge and fuel gauge use the same regulator, so if one or the other is working properly, it probably isn't the regulator.
Psycheonabike
Re: Fuel Gauge
Post #12 by Psycheonabike » Fri Jul 19, 2019 4:29 pm
Bugger....I guess that means a new sensor then?
chewy999
Re: Fuel Gauge
Post #13 by chewy999 » Sat Jul 20, 2019 7:23 am
Connect an ohmeter to the two contacts on the float assembly and then manually operate the float. The reading on the meter should go up and down. That at least checks that part. I soaked my float sender in white vinegar, after very carefully bending the small tabs on the cover to remove it. Worked very well.
anim-cheers1 anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Psycheonabike
Re: Fuel Gauge
Post #14 by Psycheonabike » Sat Jul 20, 2019 7:56 am
Great, will give that a go over the weekend! Thanks...
Psycheonabike
Re: Fuel Gauge
Post #15 by Psycheonabike » Sun Jul 21, 2019 4:47 pm
All fixed. Just rewired. Must have been a break in one of the wires.
Who is online
