Handle Bars Sizing
Moderators: robin1731, CYBORG, Oldewing, Forum Moderators
Funkdoctor
Zinc Member
Zinc Member
Handle Bars Sizing
Post #1 by Funkdoctor » Thu Jul 18, 2019 7:44 pm
I am attempting to purchase this handle bar from Cognitomotto.com was trying to see if this should be an easy swap. Or will I need to buy some adaptive pieces to make it fit. It is offered in 7/8 and 1 inch.
https://cognitomoto.com/products/biltwe ... 5e99&_ss=r
low-side
Re: Handle Bars Sizing
Post #2 by low-side » Thu Jul 18, 2019 8:19 pm
If this is for a '78, your bars are 7/8". You'll need custom length clutch and throttle cables to use those bars.
Post #3 by ericheath » Fri Jul 19, 2019 6:33 am
I would recommend using the width measurement and transfer it to your current bars to make sure you’ll like it.
Tougher is finding mirrors that your arms and shoulders don’t block your view. They sell extenders to help with that.
pidjones
Post #4 by pidjones » Fri Jul 19, 2019 8:50 am
Pretty pricey for common painted bars. I bought several through Amazon similar style. The main problem with the lower bars is not the length of the clutch cable, but rather the routing. It gets really awkward if using the stock clocks. Throttle cables can be delt with without changing the length as long as you don;t mind them poking out some. Make sureveverything gets routed according to the drawings in the service manual.
2006 GL1800 - the Black Pearl
1979 GL1000 project - to be restored
Ex '79 CB750F rat bike - the Rocket - SOLD!
Ex '75 RD400
Funkdoctor
Zinc Member
Zinc Member
Post #5 by Funkdoctor » Fri Jul 19, 2019 6:14 pm
Thanks for all the info. Definitely thinking a mechanic should do this.
Who is online
