GL1200 Clutch Slave Weep Hole?
Lucien Harpress
Post #1 by Lucien Harpress » Thu Jul 18, 2019 9:47 pm
I just recently learned that the clutch on my GL1200 is leaking. Apart from touching up the paint, repairing the clutch slave cylinder looks pretty straightforward, and in fact I've already got the rebuild kit reordered. That being said, I did notice a small hold on the bottom of where the slave bolts up to the engine block, and I'm curious it this is normal (for drainage, or whatnot).
Normally I wouldn't mind, but A) the hole itself looks pretty roughly-cut., and B) I have put this bike into a ditch at least once. It's a long shot such a targeted area would be damaged by that, but it'd be nice to rule things out.
I can post up a picture of what I'm talking about if anyone has questions.
1969 CT90- Needs some General Motor Work
1976 GL1000 (Yellow)- Minor Cosmetic Fixes, but a Good Daily Runner
1984 GL1200 Standard- Waiting on Saddlebags....
1980 KZ1300- Carbs Being Temperamental. Possible Charging Issue.
1972 CB750 Barn Find- Lots.
flyin900
Re: GL1200 Clutch Slave Weep Hole?
Post #2 by flyin900 » Thu Jul 18, 2019 10:25 pm
It's been a long time since I rebuilt mine on the 84, so honestly I don't recall. It makes sense though, if the slave starts to leak you want it to go somewhere to the outside rather than past the seal the push rod goes through and into the engine oil. Bearings don't like that mix.
Current Bikes:
1967 CL175 Low production number with #802 as engine serial- winter 2019/2020 project.
1978 CB550K Very original bike with only 7499 klms from new- light cleanup and refresh pending.
1981 GL1100 Standard model - Sept 2018 start of cosmetic refresh, nice original condition.
1983 CB1000 Custom-Low mileage full cosmetic restoration back to factory new.
1984 GL1200 Standard model in showroom condition-two owner bike.
1984 CX650E Restored summer 2017 - a rare Eurosport model-excellent one owner bike.
Who is online
Users browsing this forum: the vicar and 1 guest
