GL decals/emblems - chinese fingers
kenai
Post #1 by kenai » Fri Jul 19, 2019 4:55 pm
Hi All - the above are attached with round chinese finger gizmos on the posts. Any easy way to remove these?..thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
flyin900
Re: GL decals/emblems - chinese fingers
Post #2 by flyin900 » Sat Jul 20, 2019 11:51 am
Very small flat bladed screwdriver to carefully bend up one or two of the metal tangs away from the plastic posts. You can break off the post if your not careful with the prying job. The metal tangs are still available new from Honda, or by bending the tangs back down when they are off the post they can be reused again.
Official term for those chinese fingers is a “ speednut”!
Current Bikes:
1967 CL175 Low production number with #802 as engine serial- winter 2019/2020 project.
1978 CB550K Very original bike with only 7499 klms from new- light cleanup and refresh pending.
1981 GL1100 Standard model - Sept 2018 start of cosmetic refresh, nice original condition.
1983 CB1000 Custom-Low mileage full cosmetic restoration back to factory new.
1984 GL1200 Standard model in showroom condition-two owner bike.
1984 CX650E Restored summer 2017 - a rare Eurosport model-excellent one owner bike.
Shadowjack
Post #3 by Shadowjack » Sun Jul 21, 2019 8:23 am
Chances are extremely good that the post will break if you put any stress on it. The plastic gets soft as it ages.
Sidecar Bob
Post #4 by Sidecar Bob » Wed Jul 24, 2019 12:10 pm
flyin900 wrote:Official term for those chinese fingers is a “ speednut”!
And IIRC, they were an American invention, not to mention that the bike is Japanese, not Chinese.
In the past I have broken the pins off to remove the logos and then drilled the logos to accept small oval head bolts. If you aren't constrained by using the original holes you can drill the holes in the middle of the O and A and use black bolts and they will look like they are supposed to be like that.
You could also use a quality 2 sided tape (I believe 3m produces one specifically intended for emblems).
Or you could do what I did and have a sign guy make up some peel & stick logos to replace the 3 dimensional ones.
Mr. Honda ('83 GL1100/Dnepr) summer New Engine Thread
Who is online
