Question about points
- cmyoch
My points system was replaced a few years back from a new unit I had purchased from a local indy shop. I've had issues getting them adjusted perfectly according to the service manual but adjusted well enough to ride. Last night I spent the better part of the evening messing with them to absolutely no satisfaction. I set both points gaps perfectly to 0.016. I set the 1-2 cyl timing perfectly. I could not get 3-4 timed at all no matter how far I adjusted the points plate. In order to get the 3-4 points adjusted, that gap ended up set at 0.011 which is on the extreme opposite end of the range.
I'm wondering if my points setup is just flawed. I may ditch any chances of making this work and either shop for a replacement set or see if I can find a reasonably priced electronic ignition. Anyone else have issues like this? How do you think this can be resolved?
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
Re: Question about points
As I recall, you can play with the points gap a bit to get them more even. If I'm wrong, someone please correct me. You can get a Dyna S ignition for around $125 if you shop around.
- tlbranth
Timing the GL1000 is a tedious, thankless job. As you've found, 1&2 time easily because the plate is a pretty good fit in the casing and there's not much slop. When you get to 3&4 things get nasty. There's so much slop that when you try to move the points, the gap changes. All I can say is: what you're experiencing matches my experience. You just need to persist. If the adjustment just won't go any further, gap adjustment is necessary just as you found. Get it timed, make sure your capacitors are good and if you've got a few bucks to spare, put on a Hondaman box. You'll never fuss with it again.
http://sohc4shop.com/catalog/product_in ... be5720d03f
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- cmyoch
$78 seems like a cheaper fix to me if I don't get this sorted out.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
If you have not, use something between the contacts of the # 1 2 set while adjusting the timing on the # 3 4 set. The electricity will flow through the 1 2 contacts and give a false reading when you are adjusting the 3 4. A piece of match book or writing paper folded up a couple times. Just something break the electrical contact.
- cmyoch
I used the ohm setting on my meter to set the timing. Will the paper trick affect this the same way.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
I don't know. I suppose it would depend on the scale it is set to.
- flyday58
I hunted a bit on ebay to find NOS Honda points and it still took a lot of aggravation to get them sorted. There was a seesaw thing going on between the two sets, i.e. get 3/4 sorted and the opening point changed on 1/2. Back and forth but finally got it.
I use a timing light that I bought about 10 years ago for my enduros, it takes a 9 volt battery and has alligator clips. I also do like el presidente says and isolate the opposite set of points with thick paper.
2005 BMW R1200GS
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
- cmyoch
I did a little searching on the internet this morning. Although I can buy a new Dyna S ignition to mate up with my new Dyna green coils, that's another larger bill. I can get replacement points off of the Randakk site for approximately $20. I'm wondering if I may be better off going this route?
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
- tlbranth
If your Dyna goes bad in the Utah desert, you'd better have triple-A and good cell service. If your Hondaman box fails in the same place, you can bypass it in 5 minutes and go back to straight points.
I'm sure this will stir the hornets' nest.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- BlueThunder
+1. That is the reason why I went with the HondaMan box.tlbranth wrote:If your Dyna goes bad in the Utah desert, you'd better have triple-A and good cell service. If your Hondaman box fails in the same place, you can bypass it in 5 minutes and go back to straight points.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- dontwantapickle
I have never had an electronic ignition box go bad on me, in the desert or anywhere else.
(that's including the old crap boyers for brit bikes.)
Realistically, any component on a bike can fail, if it's not the black box... it might be a coil (better carry a spare one of those), a wheel bearing, a crankshaft......
Man, I'm gonna have to get some bigger saddlebags.
I should add, I don't have any problem with points, when set up correctly,,,they definitely get the job done.
I plan to experiment with 2 Ford TFI modules connected up like the Hondaman setup.
Carry the points plate assembly, rotor for cam, leave condensers in place but bypassed and if the Dyna fails, your in business with a little labor.
I wonder if the new “cheap” points can be adapted to grease like originals. Mike Nixon has a pretty good write up as to why the TEC were superior. Having the rubbing blocks wear down quickly was the downfall of the cheapies.
I have a new set of TEC but I’m keeping them as a backup. I got them for $50 a few years back, after reading Mike’s post.
Unless your sure the points are FEC or TEC they may not be setable. some aftermarkets are so bad they can't be set. If they are goods ones pull everything off and start over per Mike Nixon' s sequence. Sometimes it seems unbolt all and rebolt really helps.
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- 33 Replies
- 726 Views
Last post by gltriker
- 663 Views
Last post by Old Fogey
- 16 Replies
- 675 Views
Last post by OldRider2
- 3 Replies
- 259 Views
Last post by Whiskerfish
- 6 Replies
- 467 Views
Last post by Sidecar Bob
