Exhaust Muffler Replacement
- Zinc Member
So I have two holes on my muffler on the bottom. I am going to put exhaust tape on for temporary repair but It has been hard to source a replacement. Stock was fine. Anywhere I can find a pair?
- Zinc Member
Re: Exhaust Muffler Replacement
I have a 78
- flyin900
If the holes are small and not visible then a repair could be possible with some Tech Steel compound which will fill and hold well on a muffler repair. Replacement is always nice when available if someone has a pair to offer you.
Current Bikes:
- Zinc Member
flyin900 wrote:If the holes are small and not visible then a repair could be possible with some Tech Steel compound which will fill and hold well on a muffler repair. Replacement is always nice when available if someone has a pair to offer you.
Any after market options?
- tomk1960
Harley take-off mufflers are always a low-cost option. You'll need a pair of reducing flanges to make them fit the stock header pipes and a pair of brackets for hanging them from the passenger footpeg mounts. They look decent and sound really good. Nice mufflers can be had for next to nothing...or even nothing!
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
Are they rust holes or are they the drain holes from the factory? I ask since you mention only two holes.
- Zinc Member
Legit rust holes
- andorragl
Here you are a perfect reproduction, but very expensive: https://www.siriusconinc.com/pro-detail ... _id=122089Funkdoctor wrote:flyin900 wrote:If the holes are small and not visible then a repair could be possible with some Tech Steel compound which will fill and hold well on a muffler repair. Replacement is always nice when available if someone has a pair to offer you.
Here an aftermarket pretty cool: https://4into1.com/delkevic-4into2-stai ... gold-wing/
And here you are more options: http://www.randakksblog.com/gl1000-muffler-options/
I'is hard to find an used OEM, but occasionally I have seen some in good condition on eBay.
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
Andorragl he is after 78.
78/79 OEM replacements are very rare. If you are doing a full restoration there are some around but expensive. If you are just looking for a riding set then I would definitely look for some Harley take offs. I have a left and right Honda OEM on my shelf but they would cost as much as some bikes for me to let go of.
- Zinc Member
I found a number of them. Is there a particular model that works well?tomk1960 wrote:Harley take-off mufflers are always a low-cost option. You'll need a pair of reducing flanges to make them fit the stock header pipes and a pair of brackets for hanging them from the passenger footpeg mounts. They look decent and sound really good. Nice mufflers can be had for next to nothing...or even nothing!
- andorragl
Sorry, I didn't see itWhiskerfish wrote:Andorragl he is after 78.
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
Early sportster. They won't have catalytic converters in them. Also look for one's without the crossover. Makes for a cleaner look.Funkdoctor wrote:I found a number of them. Is there a particular model that works well?tomk1960 wrote:Harley take-off mufflers are always a low-cost option. You'll need a pair of reducing flanges to make them fit the stock header pipes and a pair of brackets for hanging them from the passenger footpeg mounts. They look decent and sound really good. Nice mufflers can be had for next to nothing...or even nothing!
- Sandy
Take offs worked for me.robin1731 wrote:Early sportster. They won't have catalytic converters in them. Also look for one's without the crossover. Makes for a cleaner look.Funkdoctor wrote:I found a number of them. Is there a particular model that works well?tomk1960 wrote:Harley take-off mufflers are always a low-cost option. You'll need a pair of reducing flanges to make them fit the stock header pipes and a pair of brackets for hanging them from the passenger footpeg mounts. They look decent and sound really good. Nice mufflers can be had for next to nothing...or even nothing!
- 1977 GL1000.jpg (155.87 KiB) Viewed 204 times
I went the HD route as well even tho I have an almost new pair sitting in my stockpile.Sandy wrote:Take offs worked for me.robin1731 wrote:Early sportster. They won't have catalytic converters in them. Also look for one's without the crossover. Makes for a cleaner look.Funkdoctor wrote:
78 GL1000 Original Owner 131k
I went with Emgo reverse megaphones. Dont run them lean like I did, blued up badly.
Probably will replace them with the same once I'm done carb tuning.
1979 GL1000
2001 DRZ400
1983 CR480
2001 DRZ400
1983 CR480
- 10 Replies
- 369 Views
Last post by cfairweather
- 0 Replies
- 533 Views
Last post by gltriker
- 15 Replies
- 1114 Views
Last post by salukispeed
