Found A Hole In One Of The Carbs ?
- Dr. Frankenstein
In the process of boiling and cleaning my 755A carbs, I found this in one of the throats - that jagged hole in the middle.
What bothers me is that none of the others have this, and it doesn't look like it's supposed to be there:
DSCN1557 by Dr. Frankenstein1, on Flickr
So I flipped it over and saw this, too - another jagged hole in the middle recess:
DSCN1554 by Dr. Frankenstein1, on Flickr
I blew some air through it, and it does come out the other hole. None of the other carbs have this hole here, and it sure doesn't look like it's supposed to be there...or is it? And if not, is there a fix for this? I was thinking a small dab of JB Weld, pressed in and smoothed out.
And here's what I found when I cleaned out my engine sump - pretty nasty. I put the screens in vinegar though and they cleaned up like new:
DSCN1544 by Dr. Frankenstein1, on Flickr
Re: Found A Hole In One Of The Carbs ?
I believe that hole is for the vacuum signal to the air cutoff valve. One of your float bowls has a port there and it needs to mate with that carb to get a proper signal to air cutoff valve. It enriches the mix on deceleration to prevent backfires.
Yup, it is suppose to be there. What Momma Honda declares as a hole, no one shall doubt.
- Dr. Frankenstein
Whew, Thanks! OK, Good to know!
And that isn't your engine sump. The sump is the bottom part of the engine where the oil runs down to so the oil pump can pick it up and re-circulate it (that's why these are called "wet sump" engines).
The part in your pic is what Honda calls the "Breather Chamber".
- andorragl
I had the same problem in three of four carbrs. In my case it was after an ultrasonic cleaning.
Here you can take a look https://www.ngwclub.com/forum/viewtopic.php?f=1&t=65027
I can only tell you that the bike works well.
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
Would be great to update and close out that thread, then.andorragl wrote:I had the same problem in three of four carbrs. In my case it was after an ultrasonic cleaning.
- andorragl
I'm sorry I completely forgot to report and close this thread.pidjones wrote:Would be great to update and close out that thread, then.andorragl wrote:I had the same problem in three of four carbrs. In my case it was after an ultrasonic cleaning.
I finally mounted the carburetors and to this day they are working perfectly.
I've no idea how can I close it.
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
Your comment pretty well closes it. Just a report of problem solved and how lets others that search for "hole in carb" know this was resolved.
- 14 Replies
- 998 Views
Last post by Lowrider Bud
- 8 Replies
- 277 Views
Last post by Audiowize
- 21 Replies
- 1598 Views
Last post by 6adan
