Good Morning All,
I have a 1992 GL1500 Interstate that I acquired after it had been wrecked. To make a long story short the main damage was to the plastics and my thoughts were to strip this beast down to the bare minimum and see what I wound up with in the end. Sooo....... before doing any research and assuming that the ignition (timing) was going to be "standard" I have the entire harness off the bike and went to build back up when I realized that I might have just bit off more than I was planing on. Is there a way to easily get spark to the plugs without the ECM? I don't want all the sensors and safeties, and wasn't even planning on going out of the way to keep reverse. I just want the motor running sooner than later. Thanks in advance for your help with my dilemna
GL1500 Ignition/Timing w/o ECM
- 05c50
Re: GL1500 Ignition/Timing w/o ECM
Although the GL1500 wiring is not nearly as complicated as the GL1800 and other modern bikes, it still uses many inputs to the ecm to make the engine run. The ecm uses inputs from the pulse generators to control the coils so they will need to be connected. You will also need to make provisions to control the fuel pump as well as bypass the ignition kill switch and side stand switch. There's probably a couple other inputs also. Probably easier to plug everything back in to the harness.
......Paul
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
I’d start with the 1500 schematic/wire running list, mark it up and make some decisions based on that analysis. Might make the difference between scrapping the old harness or deciding to keep it.
- tlbranth
I would take a look at the schematic as dr suggested and see if the ECM inputs could be faked by supplying +12v or ground here and there. Then just use the ignition end of it. I'm OK with electrics but throw my hands up when it comes to electronics. But it might be possible to deduce what the ECM wants to see.
My friend put a modern Subaru engine into a '72 VW bus. He used the Subaru harness and faked all the stuff the VW couldn't provide. It's doable I'd say.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- Zinc Member
I have a 1990 GL1500 that i just got all the plastics off of and have no plans to put back. very interested in your project as i did basically the same thing to this point.
- 26 Replies
- 4851 Views
Last post by C5Paul
- 28 Replies
- 842 Views
Last post by Seb Astian
- 6 Replies
- 297 Views
Last post by robin1731
- 25 Replies
- 1685 Views
Last post by foolsgold
- 1807 Views
Last post by mikenixon
