Missing starter chain
Hmmm. Where could it have gone?
Re: Missing starter chain
Mice?
Good question. Was it a quiet exit, or did it make a lot of noise. Or did someone forget to install it when they had the cover off? Guess it didn't run to good70sbudget wrote:Hmmm. Where could it have gone?
It fired when I got it, then noisy cranks and then no catch and had symptoms of a bad starter clutch so pulled to service and inspect and guess we found the issue but where would it go?
It's in there somewhere. Try magnet fishing?
Read my comments of the FB page.
I’m hoping it’s behind the stator and wrapped around the starter clutch mechanism, but I didn’t think there was room there for it. I never thought it possible, but if broken, it looks like it could get pulled past the kick-start mechanism and into the output shaft and then the gears. And then- - not good. Robins suggestion might tell the most without a full tear down. A magnet could find debris via the oil return galley under the cams.
so, the thing slipped out when i cracked the case and pulled the cover off. it was hiding in the oil.
LOL
- Pony Ruiz
I can relate to that.....daily
1978GL1000 naked - kinda sadly gone. no bike at the moment.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
So it was the mice that took it after all. Lol
