Bent Shift Lever
sphen
Bent Shift Lever
Post #1 by sphen » Mon Mar 30, 2020 1:29 pm
As the subject implies, the shift lever on my project bike is bent. Not real bad, but enough to make the angle kinda weird. Two possible thoughts on the matter:
1- Is it possible to heat it up with a propane torch and persuade it back into position, or
2- are there any nice aftermarket units available? like a nice billet or anodised lever? Plenty of used OEMs out there, but wouldnt mind something nicer.
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: https://ngwclub.com/forum/viewtopic.php?f=30&t=71959
tlbranth
Re: Bent Shift Lever
Post #2 by tlbranth » Mon Mar 30, 2020 1:35 pm
I've fabbed lots of stuff from steel. I'm no expert but it's been my experience that to bend steel rod the way you want it to go, it needs to be cherry red. That means Oxyacetylene. But if it's just a bit out of shape, I'd hold it in a vise and bash it with a big hammer.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
sphen
Post #3 by sphen » Mon Mar 30, 2020 1:58 pm
thanks. i did try a hammer, but i didnt try a big hammer...so i'll try that.
and i was kinda thinking my torch would be insufficient, and that cherry red would end up melting the rubber pad in the process.
Post #4 by rcmatt007 » Mon Mar 30, 2020 2:24 pm
I would think it is a cast piece so I doubt you could get it hot enough to bend, and it you could, I would worry that the temper would be gone
76 Ltd "cookies bike" not ready for prime time,
79 project, finished,
'86 1200 (Beth's) with motorvation sidecar, July 2017 BOTM
'17 HD Road king and 08 HD Heritage softail (Beth's). I guess you can say we have MBS
tlbranth
Post #5 by tlbranth » Mon Mar 30, 2020 3:20 pm
Yes, it could break. I figured if it wasn't useful as-is it'd be worth the gamble.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Post #6 by rcmatt007 » Mon Mar 30, 2020 3:28 pm
sphen wrote:thanks. i did try a fh, but i didnt try a bfh...so i'll try that.
the rubber pad comes off
sphen
Post #7 by sphen » Mon Mar 30, 2020 4:22 pm
any aftermarket units that fit? ive yet to find one..
Shadowjack
Post #8 by Shadowjack » Tue Mar 31, 2020 8:36 am
All the Honda shift levers I've ever seen are like mild steel. If they get bent in use, just bend them back. You don't need heat, but you might need to get creative on hold to get hold of it. Or take it off and put it in a vise.
sphen
Post #9 by sphen » Tue Mar 31, 2020 10:00 am
I was able to use a 3lb sledge and a well placed hit to get it close enough for troubleshooting work for now. i could probably get it right, but the way it needs to be in a vise in order to get the correct pressure, it slips and is really hard to immobilize.
Its good enough for now - i'll come back to it later. thanks
Post #10 by rcmatt007 » Tue Mar 31, 2020 10:15 am
sphen wrote:I was able to use a 3lb sledge
a "persuader"
tlbranth
Post #11 by tlbranth » Tue Mar 31, 2020 10:27 am
The bfh I was referring to.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
BlueThunder
Post #12 by BlueThunder » Tue Mar 31, 2020 5:27 pm
How bent is this shift lever? I haven't seen a bent shift lever that couldn't be straightened in a vise and a hammer - without breaking. If it can't, then I think you have more serious problems besides the bent shift lever. ;)
...Brian
1977 GL1000 - Ox
Post #13 by CYBORG » Tue Mar 31, 2020 5:31 pm
I'd be interested in how it got bent. It lives in a pretty protected plsce
sphen
Post #14 by sphen » Tue Mar 31, 2020 5:39 pm
Its bent bc SOMEbody forgot to remove it before laying the bike over on its side during troublehooting/dissassembly...full weight went down on it juuuust right (i was soaking the cylinders in penetrant so had to level the bike over)
sigh
Post #15 by CYBORG » Tue Mar 31, 2020 6:02 pm
Thanks. I was having trouble how it could have happened, under normal conditions
Who is online
