Water pump
Water pump
Started my 1978 finally. Runs great but I think I have a water pump leak. Pump feels rtght so I thought I was good. But it has been over 20 years so....
I have done a couple 1100s and 1200 but those had 8mm bolt heads that I could get a socket on. I am concerned the screw heads on the 1000 will pose a bigger challenge. Any advice to help ease my pain?
- IMG_20200405_144757873_HDR.jpg (172.39 KiB) Viewed 585 times
- IMG_20200405_145628724_HDR.jpg (155.33 KiB) Viewed 585 times
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
1965 CA95 Benly
Re: Water pump
Impact driver is your friend here. Tap with a hammer to get that first quarter turn. They will come along...
- Pony Ruiz
Re: Water pump
if that doesn't work. take a 1/4" chisel and tap off the screw head with that. I had to do that on just about every fastener to get the front cover off on a 1000 I had. I was lucky no heads busted off. maybe put some pb blaster or other on it first. Or apply some heat, then the lubricant, then try it.
Of course replace with proper stainless something or other. I chose socket heads.
one heads up...don't over tighten the screws on the back of the cover that hold the water pump on. I did and the washers that provide the seal deformed instead of remaining flat. there was probably a torque spec somewhere I didn't follow.
Nice bike!
Nice bike!
1978GL1000 naked - kinda sadly gone. no bike at the moment.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
Re: Water pump
Can I get an impact to them all with the motor in the bike?Oldewing wrote:Impact driver is your friend here. Tap with a hammer to get that first quarter turn. They will come along...
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
Re: Water pump
Tap off?Pony Ruiz wrote:if that doesn't work. take a 1/4" chisel and tap off the screw head with that. I was lucky no heads busted off.
Nice bike!
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
- Pony Ruiz
Re: Water pump
as in put the chisel on the screw head and tap / hit it counter clockwise.
Re: Water pump
Screw head drive configuration is JIS, not Phillips.
Not sure whether they are JIS # 1 or #2.
VESSEL makes very good JIS screwdrivers.
Find them on Amazon.
Although I haven't purchased one of their VESSEL Impacta screwdrivers for this type of service, someone may have. ???
Done.
Done.
Cliff (74yrs )
Re: Water pump
+1 on the JIS driver. While I haven't done a 1000's in the frame, when I did my 1100's, I used a longer 1/4 drive extension to get at a couple of the bolts blocked by the frame, and lots of pb blaster.
Re: Water pump
I do have vessel screw drivers. My concern was getting them broke loose initially.
I do not have JIC impact bits. Do the offer them?
And I am also worried about the accessibility of all the screws with the motor in the bike.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
Re: Water pump
tory wrote:I do have vessel screw drivers. My concern was getting them broke loose initially.
The regular bits for a hand impact fit the screws fine. #2 bit. Yes you can do it in the frame. Need an extension to get to a couple of them and you still won't be on them square but close enough to work if you are careful.
Re: Water pump
Motion Pro markets JIS 1/4" hex drive bits, available on Amazon. These may need #3. I've used an impact adapter to hold the bit. Patience is important! If you end up completly rounding out a head, use a drill (left-hand may have a chance to bite and hold) to remove the head - the drive cross should pretty well center you. After all bolts are off and the cover removed you can use more penetrant, time, and vice grips on the remaining bolt.
Re: Water pump
i bought one of the run of the mill impacts off amazon, and the included bit(s) fit JIS screws fine. IIRC it came with #2 and #3.
Any reason not to replace with hex bolts while you have them off?
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: viewtopic.php?f=30&t=71959
Build log video: View it here
BOTM November '22
BOTM November '22
Re: Water pump
Some don't like the SS in aluminum combination. It would be great if you could find the correct strength Allen heads in cadmium plated steel. Then you could snap them off after they bind up and save the drilling. I don't think there is a better solution (but there are worse - don't use Phillips head!) except to lubricate whatever you use with a good anti-sieze.
I've read good comments on Robin's bolt kit, BTW.
Re: Water pump
Robins bolt kit? Is there a link?
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
- RIP: cookie
Re: Water pump
robin1731 .... he’s a member here .... PM him and he'll fix you up ....
- 7 Replies
- 805 Views
Last post by gregforesi
- 392 Views
Last post by chewy999
- 11 Replies
- 765 Views
Last post by rooster4321
- 12 Replies
- 846 Views
Last post by CYBORG
