Brake calipers- rework or re-buy
sphen
Re: Brake calipers- rework or re-buy
Post by sphen »
I was able to get one piston out of each using the master cylinder. But I had to press them back in partly to try the grease method to get the others.
I’m missing something tho - grease just runs out and down the caliper. Not getting much in and certainly no pressure. What a mess.
Project bike "Dixie" - 1986 GL1200 Aspencade being rebuilt from ground up to be a naked 'wing. Build progress thread here: viewtopic.php?f=30&t=71959
Build log video: View it here
BOTM November '22
sphen
Post by sphen »
williwm wrote:Another way to use a grease gun is to remove the coupling from the gun and screw the guns tube lightly into the banjo bolt hole. The 1/8” pipe thread is close enough to the m10 threads to catch enough threads to pump the piston out. Don’t force the guns thread into the caliper or you’ll damage the threads, only lightly hand tight will do.
https://i.postimg.cc/SNxNYvnp/0-D47-E37 ... FDB7-B.jpg
That sorta worked - once it pressurized the grease started oozing out around the unstuck piston and then back out the banjo hole. Then I ran outta grease. Sigh
sphen wrote: Tue Apr 28, 2020 7:57 pm
You need to seal off the banjo bolt. I stack crush washers on a bolt for that. Also wrap the bleed screw with teflon tape.
sphen
Post by sphen »
This is a bit of a zombie thread at this point, but
Ultimately I found a short bolt with matching threads, sealed with Teflon, and got the grease gun properly attached.
BOTM November '22
redglbx
#20
Post by redglbx »
One thing I haven’t seen mentioned here at all is that while using a grease gun to remove the pistons works very well you must replace all the rubber seals that contact the grease and spotlessly clean all the grease from the caliper. No residue at all.
This is because “grease” is a mineral oil based product that will kill brake fluid based seals ! You cannot clean and reuse them, throw them away ! Any amount of contact with a mineral oil based product will cause the brake fluid seals to swell & fail ! Final cleaning of the calipers or any brake parts should be with only pure alcohol or brake cleaner only.
pidjones
#21
Post by pidjones »
Yes, need to toss all of the rubber. But on a froze-up caliper that should be done, anyway. I put my grease-laden calipers in a tub (plastic coffee can) of kerosene to soften and remove the grease, then a thorough bath of brake cleaner. For the blanking bolt, one caliper of one of my rescues was a blank fine-thread bolt (THAT caliper didn't leak!) I've used that bolt since then as a blanking bolt.
#22
Yeah, it's pretty much a given if you are removing the piston everything needs replaced and thoroughly cleaned.
sphen
#23
Post by sphen »
True in my case also - complete rebuild/bath/etc
BOTM November '22
