from serial #1000001-1011239 these early clutches had a damper plate installed near one end or the other of the clutch plate sequence...
the cure is to relocate the damper plate to the centre of the assembly......
safe riding.....................all
solving clutch chatter in early gl1000
- Bandanna
- Try
- NGW Founder
- My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: solving clutch chatter in early gl1000
A nice one bandanna, keep up the good work!bandanna wrote:from serial #1000001-1011239 these early clutches had a damper plate installed near one end or the other of the clutch plate sequence...
Try
"84 - GL1200 Standard
Try
- alan hawke
- My Album: http://www.ngwclub.com/gallery/v/wingmans//alanhawke
Absolutely correct bandanna.I had that problem a couple of years back ,clutch chatter , clutch grabbing at a stand still while in gear. Could never select neutral while bike was running ,No matter how i adjusted the clutch it was never any good . I pulled clutch and located damper plate to the middle and it fixed the problem ,it's now and has been a pleasure to ride ever since.bandanna wrote:from serial #1000001-1011239 these early clutches had a damper plate installed near one end or the other of the clutch plate sequence...
PS. The damper plate in question is a thicker plate than the rest so is quite easy to pick from the rest .
Cheer's Alan.
ngw
Alan
1976 GL1000
2000 ZX6R KAWASAKI
2009 vn1700 kawasaki classic
1976 GL1000
2000 ZX6R KAWASAKI
- Zryder
- My Album: http://www.ngwclub.com/gallery/v/wingmans/zryder/
Thats great Bandanna . I learn something everyday , and Thanks for the tip also , Alan . I wandered that myself where most times I could not put the bike in nuetral while running , but I was able to cure it by adjusting the clutch , I wandered if the took care of it by 82 ? Thanks again brothers .
1982 GL 1100 std. Custom
