Carb sync tool
- Tin Member
Carb sync tool
Hello all, perhaps this has been asked before, where is the best place to find the old style mercury carb sync tool, or perhaps there is something new and improved??? thnx
Re: Carb sync tool
- ritalz
Re: Carb sync tool
Not likely to find mercury stix anymore because mercury is classed as a dangerous item. You can get a set of gauges from some of the suppliers on the web.
- rjdoles
Re: Carb sync tool
When I had my Shadow's I made a u-tube manometer for about $25. I made it from a 25' length of 1/8" clear plastic tubing that I purchased from one of the home improvement stores. See picture.
I drilled holes about every foot along both sides of the 6' length of a 1 x 2" to feed wire ties through that will secure the tubing. The center of this 25' length of tubing will be attached to the bottom of the 1 x 2" and then wire tires will secure the tubing up both sides of the 1 x 2".
You probably need a restriction to slow the motion of the fluid. I cut a 1" length of a brass bolt. I drilled a 1/32" hole through the bolt. I cut my plastic tube at the midpoint and inserted the restriction into the two cut ends. It is important that the restriction is at the bottom of the U so that it restricts the fluid movement. Fluid is not compressible and the air above it is.
You could use water but I preferred a colored liquid so I used automatic transmission fluid. It has a specific gravity of about .87 and I added it until it filled the bottom of the u-tube to about 30" on either side of the 1 x 2". ATF is about 1/16 of the specific gravity of mercury so the fluid height difference between the sides of the u-tube makes this manometer is about 16 times more sensitive than if you were using a mercury based manometer.
I ordered MotionPro 5 mm adapters for about $10 on Ebay which match the fittings on our carb elbows. I drilled a hole in the top of my 1 x 2" and hooked a coat hanger through it and hung my manometer from a rafter in the garage.
I start synching by threading the MotionPro adapters into the right side carb elbow's 1 and 3 which are supposed to be adjusted first and then I adjust to get the balance within an inch or two. Remember that using ATF makes this about 16 times as sensitive as a mercury manometer so don't try to get them perfect. I move the MotionPro adapters to carb elbow's 2 and 4 and adjust the left side balance to within an inch or two. I then move the MotionPro adapters to elbow's 3 and 4 to adjust the left/right balance to within an inch or two.
I am happy with the results.
Started with an Allstate stooter made by Cushman and then a series of Honda motorcycles. 305 SuperHawk, CB750, VT600DC, VT750CD and then 4 years ago I left motorcycles for scooters with an Elite 125, Reflex 250 and Silverwing 600. Most recent is a barn find 77 GL1000 that I plan to resurect.
Re: Carb sync tool
Working with a "Carbtune Pro" myself. I'm a bit of a newby but it seems to be doing the trick. Simple to use and all mechanical. The DIY ATF syncs look cool but you end up spending a lot of time gathering parts and messing with them etc...witch might be your thing! Haha! Plug and play is nice in my book.
1979 GL1000 Early Stages of Rebuild 08/01/2020 First Shot at it!
- Jonesz
Re: Carb sync tool
Just bought a Digi-synch. Very cool tool. Took less than 15 minutes to do my 78 gl1000 and now have no popping/miss at idle. Not cheap but have a couple of buds who pitched in some $. One of them, a mechanic used it yest to tune his 4 cyl merc boat engine. He thought it was a great way to synch the carbs. You would need to buy 4 (5 mm adapters to do flat fours with 4 carbs)
Jonesz
1979 Suzuki GS850. Sold
- Dr. Frankenstein
Re: Carb sync tool
I use a Morgan Carbtune II; I've had it for some time and used it successfully in my 1985 Virago 700 and my KZ650; stainless steel tubes, so no worries about sucking fluid into the chambers. Kind of pricey ($100), but well worth it, I think.
https://www.carbtune.com/
Re: Carb sync tool
I also use the Carbtune. Absolutely wouldn't give it up for anything. Although hundred bucks is steep, for me it has been amortized across a bunch of motorcycles. It has paid for itself many times over.
- Tin Member
Re: Carb sync tool
Thanks for the replys, appreciate the feed back.
