Dyna install
- Tin Member
Dyna install
Still no pictures on the Octane Dyna install.Which would not be as big a deal if i had'nt started my Dyna and coil install the day they went down
Re: Dyna install
This is the one for setting the timing. it might help.
viewtopic.php?f=22&t=5720#p44990
Octanes album associated with the install post is here: https://ngwclub.com/gallery3/index.php/ ... e/album111 Unfortunately I do not know when I will get to reloading those pics in his thread
Re: Dyna install
Octane’s writeup is excellent and will definitely get you up & running. I would add that once you have things setup that you go back and remove the left cam belt cover, install a degree wheel (randakk sells one that makes things pretty easy, cheaply made but works 100%) and do the timing dynamically with a timing light.
As several have commented that setting the timing staticly as in Octanes write-up tends to over advance the timing, does it make a big difference ? Probably not ! But for me, my opinion is that things seem to run better when set dynamically, a big plus is that using the degree wheel allows you a more precise setup picture particularly for the balance between the 2 cylinder sets. It’s the only way I do my bikes anymore. But again, if you simply follow Octanes write-up you can’t go wrong but imho doing it dynamically gives a smoother running bike. My .02
- Tin Member
Re: Dyna install
Thanks guys.This will all help
- Tin Member
Re: Dyna install
so still having fun here. On Octanes excellent install post he refers to the removal of the cam ;sleeve as tricky. After two days of trying to get it off can anyone tell me what the trick is?
Re: Dyna install
I am assuming you have the advance mechanism off of the bike at this point. First, with one hand, spread both weights to the max and carefully pry the cam off using a small screwdriver with the other hand. On some, it is easier to remove the weights by removing the E-Clips and sliding off the weights. If you do this, be careful not to loose the tiny, thin shims. The earliest wings had a pin on the shaft so you will need to grind/cut this off with a Dremel tool if you have one.
- Tin Member
Re: Dyna install
Cedrick if I ever make it through all this it will only be because of your more than generous mentoring. got it off and the Dyna mounted. Onwards and upwards
- 755 Views
Last post by robin1731
- 10 Replies
- 475 Views
Last post by bonestock3
- 21 Replies
- 1323 Views
Last post by Fred Camper
- 9 Replies
- 1139 Views
Last post by pidjones
- 4 Replies
- 403 Views
Last post by silverbullit
