I present to you the Binford GL1000 snap ring tool
5speed
Post by 5speed »
So like everyone here..I struggled to get the snap ring off the driveshaft. My problem was..the snap ring plier tips would slip out of the clip as soon as any tension came on the tips. Even my good pliers did the same thing.
So I whipped this bad boy up this morning using 2 allen wrenches.
Second attempt and got the snap ring off. dancr
The tool.
Why it worked so well. It fills the holes in the clip and the edges on the allen wrench help grip the snap ring.
At first I tried them using the entire wrench but it was to long and I was losing the torque so I cut them a bit longer then the tips that came with the pliers in hopes it would give me some eye ball room between the pliers and clip.
It worked so well I'm giving myself the rest of the day off. :lol:
Jonesz
Re: I present to you the Binford GL1000 snap ring tool
Post by Jonesz »
And a new millionaire enters the fold! Seriously that appears to be an excellent solution, you will have helped many of us today. Have fun on your day off.
Jonesz
1979 Suzuki GS850. Sold
5speed
Post by 5speed »
Jonesz wrote: Sun Mar 28, 2021 11:32 am And a new millionaire enters the fold! Seriously that appears to be an excellent solution, you will have helped many of us today. Have fun on your day off.
should I patent it? :mrgreen:
If it helps prevent wrench throwing, new curse words frustration for anyone it was worth it. lol
Sidecar Bob
Post by Sidecar Bob »
Having injured myself with that type of snap ring pliers one time too many I now only use the ones that are solid pliers without removable tips.
I guess if you have to use the replaceable tip type this is an improvement if only because the flats on the allen keys give the set screws something better to bear against.
5speed
Post by 5speed »
Sidecar Bob wrote: Sun Mar 28, 2021 12:52 pm Having injured myself with that type of snap ring pliers one time too many I now only use the ones that are solid pliers without removable tips.
the tips are all 6 sided as well. they were just to small.
Sidecar Bob
OK. The ones I am familiar with were round with one flat side that wasn't ground flat very well so the set screws didn't hold them well and they turned in the pliers.
I don't recall having a particularly hard time getting mine out with this type. As I recall, finding the ends of the snap ring in the grease was the hardest part...
https://www.princessauto.com/en/bent-no ... 0008007391
5speed
Post by 5speed »
Sidecar Bob wrote: Sun Mar 28, 2021 2:55 pm OK. The ones I am familiar with were round with one flat side that wasn't ground flat very well so the set screws didn't hold them well and they turned in the pliers.
I had to dig a bit to find them. lol
I have these channel lock pliers. Very well made and they are inside and outside snap ring pliers combined with a flip of that red tab.
https://www.canadiantire.ca/en/pdp/chan ... 4572p.html
redglbx
Post by redglbx »
So, I need to know,,,,,,, were Any adult beverages harmed in any way during or after all this ?
RIP: cookie
Well ... I had a couple ... and I was just reading the thread ...
Gord anim-cheers1
Sidecar Bob
I think those are the improved version of the ones I came to loathe so much.
5speed
Post by 5speed »
redglbx wrote: Sun Mar 28, 2021 8:44 pm So, I need to know,,,,,,, were Any adult beverages harmed in any way during or after all this ?
lol..no. coffee is my "go to, must calm my nerves" beverage..
although I still need to get the snap ring off the splined sleeve on the drive shaft so a stiff shot of whiskey is still a possibility. :mrgreen:
kjmarti2
Post by kjmarti2 »
Pictures already gone, he must have decided to patent it lolol
Yellow 1976 GL1000 - "The Phoenix"
1976 GL1000 LTD
2002 CB900F 919
5speed
Post by 5speed »
kjmarti2 wrote: Mon Mar 29, 2021 4:55 pm Pictures already gone, he must have decided to patent it lolol
I didn't take them down.. you can't see them?
kjmarti2
Post by kjmarti2 »
5speed wrote: Mon Mar 29, 2021 5:09 pm
Interesting. I can see them on my phone but not the computer I was using. Looks like it's all good on your end.
1976 GL1000 LTD
2002 CB900F 919
Sidecar Bob
I can see them on my computer. Maybe it is a setting on yours.
