Lester valve stem
- tlbranth
Lester valve stem
About to stick a 16" Lester on the back of my '75. Stem hole is 5/8" diameter. Alloy is thick. Source for a valve stem anyone?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: Lester valve stem
We where mounting the same wheel a couple of years ago in Cleveland. After searching both auto parts stores and motorcycle shops for the big valve. We just put a tube in her..................
I can not seem to find the source for the ones I ordered years ago but these are rated for a .625 hole https://www.summitracing.com/parts/cal-711957?rrec=true
Seems like most rated for the .625 hole are associated with truck rims
Make sure to stay away from the aluminum ones. Have read too many reports of the threads stripping out on those. Brass, steel or SS is what I would use.
- tlbranth
Thanks Whisker. It occurred to me to stop at Discount Tire when I go by there tomorrow. If they don't have one, I'll go for the one you found.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- tlbranth
Nothing at the tire shop but got a pair of stems at O'Reilley's for $7.50
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Hi Terry,
Do you by chance have an update on the Oreiley’s valve stems you found - in terms of fit & finish & and proper sealing? Also, do you happen to have the brand/part #?
Thanks,
Rocky
Thanks,
Rocky
- tlbranth
Rocky - here's the stems I got. The fit is good. Material is nickel plated brass. I don't have a tire on yet so I can't speak to how well it seals but it certainly looks like it will. My only concern is the rubber. I've had Rubber items from China go bad quickly in the past and this valve is made in China.
https://www.oreillyauto.com/detail/c/xt ... alve&pos=1
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- tlbranth
As an update: Put a new Dunlop American Elite on the Lester. Been on a week or so and there's no problems with the stem.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- 370 Views
Last post by Wangthang
- 3 Replies
- 288 Views
Last post by taunusrainer
- 4 Replies
- 347 Views
Last post by John Schmidt
- 4 Replies
- 406 Views
Last post by ianstaley
- 13 Replies
- 1087 Views
Last post by calif wingnut
