Front brakes seized
Re: Front brakes seized
I always recommend servicing the brakes completely unless you know when they were last done and that they were done properly. The brakes are the most important part of any vehicle.
A couple thoughts that may or may not be useful. The piston in the photo is shot. Even if it seals, it won't return properly with all those pits. On the rear, are you sure it's dragging or is it normal pad kiss? If the rear is easy to turn, what you're hearing might just be the leading edges of the pads skating along the rotor surface.
This. It is normal for the pads to remain 'lightly' in contact with the rotor. There is no return spring to move the pad back. It may be hard to gauge on the rear wheel due to the resistance from the final drive and shaft, but the wheel should turn freely.
That said, as Bob recommends above, if the front brakes need attention, the rear usually do too.
- Cakey
The rear wheel does not return freely, I believe. It takes a bit of force to free spin the rest wheel.
1975 Gl1000
Do you put anything in the dust seal? Brake lube? Or is it best to keep it dry?
Casey, looks/sounds like you’re due for a complete brake rebuild. The piston above is toast, I wouldn’t use it unless like whisker said it’s a must-do deal. It’ll just kill a new seal. I suspect you’re gonna find more of the same in the other calipers & m/c’s. Buy new stainless pistons and m/c rebuild kits which normally have all new parts and hopefully the bores are still good. Flush the brake fluid every 2 years or so, it’s one of those things we tend to forget about.
"Bit of force". That is relative. It does take a bit to turn the rear wheel when all is perfect. Impossible to describe how much force. Even when right the rear wheel won't make a complete revolution if you turn it with some good force with the bike on the center stand.
I did. A light smear of Sil-Glyde (silicone grease ) under the dust seal seemed a proactive step to reduce possibilities of water intrusion corrosion on the exposed piston outside diameter. Will probably wipe the inner bore of the caliper piston with high temperature silicone brake lubricant to reduce corrosion in there, too.
Cliff (74yrs )
- Cakey
How you describe it Robin, is how it is. I have ordered the parts and will do a complete rebuild back and front. They have not been done for 9 years, so it won’t hurt. The only parts I cannot get here is OZ are brake pistons and front master cylinder kit. It coul be a painful wait once I find were to order them fromrobin1731 wrote: ↑Tue Apr 27, 2021 1:33 pm"Bit of force". That is relative. It does take a bit to turn the rear wheel when all is perfect. Impossible to describe how much force. Even when right the rear wheel won't make a complete revolution if you turn it with some good force with the bike on the center stand.
1975 Gl1000
Old Fogey still has some sizes available
http://wingovations.com/stainless-steel ... 4588600239
- Cakey
Thanks Bob, that’s a really good lead. I need to get the back calliper off to see if I need any rear pistons now.Sidecar Bob wrote: ↑Tue Apr 27, 2021 3:05 pm Old Fogey still has some sizes available
1975 Gl1000
- flyin900
That contact on the rear is normal as the pads do lightly touch the rotor as you rotate the wheel. If they are releasing well, I would leave them alone. Possibly only do a complete flush of the old brake fluid in
the entire rear system.
Current Bikes:
Cake, as others have said it is normal to hear the rear pads drag the rotor a bit, but the wheel should turn fairly easily but like Robin said it won’t spin freely.
Also, make sure that the rear brake pedal returns very freely, not uncommon for those to drag a bit with time, so while you’re pulling it all apart clean and lube the brake pedal pivot. Also while we’re spending your money have you given any thought to adding braided brake lines to improve the brake feel/feedback and a little power ?
The reservoir is held on very tight by the o-ring. Those o-rings do not usually come in the rebuild kits. There is a tiny hole under the reservoir that relieves pressure back when you release the lever/pedal. It must be open. I usually rod it out with a high E guitar string. The hole on the rear master may be behind a seaming unused bolt head. I hate brakes.
- Cakey
For the life of me I cannot pull the reservoir off. It’s not the original one, it’s a new one I put on when I built the bike. I don’t want to destroy it to try and get to that hole to see if it’s blocked. Anyone have any ideas?pidjones wrote: ↑Wed Apr 28, 2021 7:19 pm The reservoir is held on very tight by the o-ring. Those o-rings do not usually come in the rebuild kits. There is a tiny hole under the reservoir that relieves pressure back when you release the lever/pedal. It must be open. I usually rod it out with a high E guitar string. The hole on the rear master may be behind a seaming unused bolt head. I hate brakes.
1975 Gl1000
- 4 Replies
- 262 Views
Last post by bulldozer
- 6 Replies
- 273 Views
Last post by Whiskerfish
- 510 Views
Last post by bagger13
- 9 Replies
- 354 Views
Last post by BlueThunder
- 16 Replies
- 763 Views
Last post by 6adan
