GL1000 UJ lubrication
KeithS
Lead Member
Lead Member
Post by KeithS »
I've read that the UJ is lubricated from the factory and any greasing of the outside (inside the rubber boot) won't really help.
As the bike is nearly back together and I seem to have overlooked that joint, do I need to mess about trying to lube the outside of the UJ with grease?
I'm about to do the rear of the shaft and splines but that is out in the open for me to do compared with the front joint!
MikeNTexas
Re: GL1000 UJ lubrication
Post by MikeNTexas »
The u joint has no provision to grease it. About the only thing on these bikes that is not serviceable.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
Paola Zago
Post by Paola Zago »
sorry, MikeNTexas, forgive my ignorance, but what would be the U-joint ?, the rear swingarm?
thank you in advance
Paola (Italy)
MikeNTexas
Paola Zago wrote: Wed May 05, 2021 8:00 am sorry, MikeNTexas, forgive my ignorance, but what would be the U-joint ?, the rear swingarm?
Paola (Italy)
Here’s a picture of the u joint.
pjlogue
Post by pjlogue »
MikeNTexas wrote: Wed May 05, 2021 8:28 am
Paola (Italy)
Mike, was that U joint rebuilt? Looks like original stake points were redone and new joint fitted.
-P.
MikeNTexas
Yes I rebuilt it using the truck steering u joint. Time will tell if it holds up.
Paola Zago
thanks MikeNTexas, it was the U-shaped term that had me confused. I see that you have rebuilt it, that's what I'm trying to do here in Italy too, I don't know if you had read my posts, it's not that I do the job, I wouldn't be able to do it, but through a friend I have contacted a repair shop that works for Ferrari Prototypes and their Sport racing cars, and they told me that it is possible to replace the joint, it was only to be established if it was better to weld or press, or define the times of processing for stable a cost. being a workshop that works for Ferrari, the costs are certainly not low, but the work should be of quality!
Paola
Sidecar Bob
Post by Sidecar Bob »
U-joint = universal joint (what you would call a Cardan joint)
Shadowjack
Post by Shadowjack »
A long time ago, I was taught that technically, a Cardan joint was TWO cross-yokes in one carrier. Used in old Cadillacs to eliminate all drivetrain vibration, IIRC.
Sidecar Bob
Sidecar Bob wrote: Mon May 10, 2021 9:33 am That's a Double Cardan Joint
https://en.wikipedia.org/wiki/Universal_joint
Well, I guess that puts an end to it :lol: :lol: :lol: :lol:
Shadowjack
Silly me.
