Found source of oil leak in weep hole - is water pump recoverable?
Well, the oil leaking out of the weep hole was likely due to damaged water pump seals rather than crush washers.
The seal for the ball bearings is toast, which probably caused the oil leak, and I haven't seen any form of circlip. Is this water pump recoverable/rebuildable or do I just buy a new one?
Water pump Oil pump. Will replace oil seal, but i assume this is still OK.
Greater Boston MA, USA
- RIP: cookie
Re: Found source of oil leak in weep hole - is water pump recoverable?
Toast ... you’ll need a new one ...
I'd confirm all the ball bearings are there too..looks like chunks of metal stuck to the oil pump seal.
I just replaced mine, bought an OEM pump along with OEM o-rings, crush washers, seals and gaskets from a guy on Ebay as a job lot. Came with everything you'll need for the replacement -
https://www.ebay.ca/itm/303984281780?_t ... 0229.m3211
Knowing I had a leak I already bought the KP gasket kit, so I'll be looking for a pump only.
they are a bit pricey but I bought mine from Honda. buy once cry once.toomanybikes wrote: ↑Thu May 06, 2021 6:10 am
- Old Fogey
PM sent.
The pump is rebuildable, and 'kits' are available. It's a relatively easy job. Check out Wingovation website for a great how-to.
- Lowrider Bud
- Zinc Member
Sure wish I would have seen this before I paid $150 for a new Honda pump - that leaks. Still hopping it takes some running to set-in.Track T 2411 wrote: ↑Thu May 06, 2021 10:05 am The pump is rebuildable, and 'kits' are available. It's a relatively easy job. Check out Wingovation website for a great how-to.
Good luck, Bud...
Time for another Road Trip...
antifreeze or oil?Lowrider Bud wrote: ↑Fri May 07, 2021 8:34 am
Good luck, Bud...
It's been done before. Pinch/roll an 0-ring or even forget to install the crush washers.Lowrider Bud wrote: ↑Fri May 07, 2021 8:34 amSure wish I would have seen this before I paid $150 for a new Honda pump - that leaks. Still hopping it takes some running to set-in.Track T 2411 wrote: ↑Thu May 06, 2021 10:05 am The pump is rebuildable, and 'kits' are available. It's a relatively easy job. Check out Wingovation website for a great how-to.
Good luck, Bud...
- RIP: cookie
Some aftermarket pumps came with the wrong size crush washers ...
- Lowrider Bud
- Zinc Member
The leak is coolant (anti-freeze). It only drips a spot about the size of a dime, and only after it's been run for a couple of minutes (I'm still trying to get it to idle right). I steered away from an aftermarket pump after reading here that "you just need to bite the bullet and buy a Honda OEM pump." I was real careful with the reassembly so I don't think I ham-fisted putting it back together.
When I get it on the street, if it still leaks, I'll go back to that problem using the re-build kit discussed above. Till then, getting it running right (or even near right) is the priority.
Later, Bud...
Later, Bud...
- Zinc Member
The pump has ceramic faced seals, mine leaked till I put a few miles on it and it stopped.
- Lowrider Bud
- Zinc Member
That's what I'm hoping for. Thanks for the encouragement.julimike54 wrote: ↑Sat May 08, 2021 3:01 pm The pump has ceramic faced seals, mine leaked till I put a few miles on it and it stopped.
Later, Bud...
- 10 Replies
- 705 Views
Last post by Sidecar Bob
- 20 Replies
- 1417 Views
Last post by 82aspy
- 21 Replies
- 2442 Views
Last post by John Schmidt
- 30 Replies
- 818 Views
Last post by rcmatt007
- 39 Replies
- 3338 Views
Last post by Rat
