Fogey, great link ! The only thing I would add is that once things are clean is that I believe that Keihin puts the slots in the emulsion tube so that you could use a screwdriver to EASILY turn the tube to orient the slots, no forcing it. My opinion !
Jack, I forgot about Jets-R-Us , good vendor !
maxv12 wrote: ↑Tue Jun 01, 2021 10:32 pm
Thanks Terry, I checked out your float tang fix tutorial. I’m going to give it a try, I actually have both soldering guns, one is identical to the large one in your pic lol.
Be sure to clean i.e. sand and flux all brass. Do the same as if you were doing copper plumbing. Good luck.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
Thanks Terry, I finished cleaning the parts and will make sure to sand and flux all the brass. The only brass sheet I could find is .016 , which is only slightly thicker. You think that will be ok?
Thanks for Old Fogeys linkRedglbx! I wish I saw that before I bent it, lol. I actually pushed them out the first time I rebuilt the carbs but like the article says they look like the end of the jets so I wasn’t thinking and tried unscrewing one, lol. You said something about the slot being there to help orient the tub. I didn’t realize the had to be positioned a certain way? Can you give more info on the specific orientation?
Oops, looks like I missed a couple of posts. Sorry Old Fogey, I should have thanked you for your link, directly. And Shadowjack, thanks for the oem jet link!
maxv12 wrote: ↑Sun Jun 06, 2021 12:38 am
Sounds a bit thin. Hobby shops have different gauges. I just eyeballed it. I'm a long way from home right now but if you can wait til I get home I could send you some. Might be 2 weeks.
Terry
Don't own a Vanagon
Life is good
I discovered another contributing factor in why my bike was not running right when I was cleaning the carb parts. One of the vacuum chamber plastic caps has a hairline crack in it that is letting air out. Can anyone recommend the best epoxy to repair it?
"Impossible Is Just a Level of Difficulty!..." If I'd wanted you to understand, I would have explained it better! (Johann Cruyff) I’d give my right arm to be ambidextrous!
'82 gl1100I, My first 'Wing, and an expensive lesson! New2U Bike? Read Me.
I have all the remaining stock of Pistol Pete's buttons.
How do you attach the new buttons? I have the impression that the edges of the opening were rolled over after the original buttons were installed to hold them in...
Hi Old Fogey, Are you selling any of the buttons that you have? If so, like sidecar bob how do you install them? Ideally I’d like mine to look original.
Track T 2411 - Do you know if cfairweather still does the caps and if so what would it cost?
maxv12 wrote: ↑Mon Jun 14, 2021 10:10 am
You can contact him by PM...
