No Spark 75 GL1000
- Cakey
Re: No Spark 75 GL1000
So I checked the ballast resistor and it’s come back at 03 ohms, which according to Randakk is spot on. I had another look at my Honda Service Manual about the diodes. It’s the 75 - 79 manual so some things are a bit different. It shows 4 diodes of which I have the first two on my bike and according to the colours my faulty one is the Ignition Bypass. No idea what that means, but it’s definitely related to ignition I think?? Maybe the source of my woes.... are the OZ bikes different to the USA bikes with the wiring?
- 3A53079D-88C5-4C73-B344-34836BDFA560.jpeg (301.65 KiB) Viewed 232 times
1975 Gl1000
OK apparently I remembered wrong.
The bypass circuit is to bypass the ballast resistor when starting to provide full voltage to the coils for a hotter spark. Once the starter button is released the ballast resistor goes back into the circuit to reduce the voltage to the coils.
- Cakey
So my problem might be the silicone diode?Whiskerfish wrote: ↑Tue Jun 08, 2021 7:13 am OK apparently I remembered wrong.
1975 Gl1000
My Gut says no. BUT I really do not know for certain. I have never heard of this being a cause for a no spark situation. At worst I think if the diode were bad the system would not bypass the Ballast resistor when the start circuit is energized. So it should have spark just not as strong as the normal start sequence.
There is a diagram here that I made years back that may help you understand https://ngwclub.com/forum/viewtopic.php ... 69#p667397
And Roncar wrote up a nice description of the Start side and how the diode works there but no mention of the Ignition side. https://ngwclub.com/forum/viewtopic.php ... 21#p135721
Your OZ 1975 GL1000 must not have the Reserve Lighting System as an OEM safety feature?Cakey wrote: ↑Tue Jun 08, 2021 3:57 am So I checked the ballast resistor and it’s come back at 03 ohms, which according to Randakk is spot on. I had another look at my Honda Service Manual about the diodes. It’s the 75 - 79 manual so some things are a bit different. It shows 4 diodes of which I have the first two on my bike and according to the colours my faulty one is the Ignition Bypass. No idea what that means, but it’s definitely related to ignition I think?? Maybe the source of my woes.... are the OZ bikes different to the USA bikes with the wiring?
If I am correct, 2 of the 4 diodes are integral with the auxiliary operation of the Reserve Lighting System.
I sorta remember some fellow member has or knows of a source for a European spec. GL1000 wiring diagram.
Cliff (74yrs )
- AussieGold
Cakey.gltriker wrote: ↑Tue Jun 08, 2021 12:50 pmYour OZ 1975 GL1000 must not have the Reserve Lighting System as an OEM safety feature?Cakey wrote: ↑Tue Jun 08, 2021 3:57 am So I checked the ballast resistor and it’s come back at 03 ohms, which according to Randakk is spot on. I had another look at my Honda Service Manual about the diodes. It’s the 75 - 79 manual so some things are a bit different. It shows 4 diodes of which I have the first two on my bike and according to the colours my faulty one is the Ignition Bypass. No idea what that means, but it’s definitely related to ignition I think?? Maybe the source of my woes.... are the OZ bikes different to the USA bikes with the wiring?
i have a colour coded wiring diagram , for AU models. I have emailed it to you.. AU models do not have the reserve lighting module.
there are several other differences to the US model re wiring.
but , if the problem is no spark, the first thing to check will be power to the coils.
from memory,
red wire from battery to ignition switch.
black wire from ignition switch to ballast.
black/brown wire from ballast to kill switch on handle bar.
black/white from kill switch to coils.
diodes allow power to run one way , but i doubt they are your problem. one on AU model is for the clutch switch
override , the other for start circuit. if your bike is turning over i doubt there is a problem there.
as mentioned , the ballast resistor is bypassed when the start button is pushed.
a simple test to see if the ballast is faulty, is to unplug it both ends and connect the two wires together.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
I vaguely remember a Topic started a year or two ago that may have been a little like this one. The engine would crank over, but not start. No spark.Cakey wrote: ↑Tue Jun 08, 2021 3:39 amThanks Whiskerfish. Dyna has power at the red wire. I have ordered another diode today in Australia, from a motorcycle wreckers who had one on a Honda XL175 (same diode). Is there a reference somewhere on how to test the ballast resistor on the GL1000? New to me.Whiskerfish wrote: ↑Mon Jun 07, 2021 8:05 am I have not looked in a while but I do not recall the Ignition circuit going through the Diodes? The Starter circuit yes for the safety interlocks.
You have a dyna right? So first check power for the dyna. On the 75's most people used those blue scotch locks to tap power from the turn signal wire under the left side shelter. Once you verify you have power for the dyna then verify power for the coils. I would do that at the Ballast resister.
Ignition circuit power comes out of the Key switch then to the Kill switch and start button but I do not think it goes through the diodes????
The thread had a lot of discussion. Finally, a member offered up the suggestion to check the 3 multiple wires connectors on the front left corner of the shelter frame. Just to the left of the fuse box.
As I recall that offering member said he found a questionable connection in one of those connectors on his GL1000.
The suggestion he had offered up, actually turned out to be the solution!
While you are waiting for the diode, in the meantime, this is another area to proactively consider inspecting, too.
Cliff (74yrs )
Aussiegold's UK/Aus wiring drawing is also available through the link in my signature AND the Shop Talk section of the forum.
As has been mentioned, one of the diodes is for the clutch/neutral interlock system (the drawing below is not exactly the same as in the 1000 but it works the same way) and the other is part of the circuit that bypasses the ballast resistor while the Start button is pressed. Neither of them should prevent the ignition system from producing sparks.
The first question that needs to be asked is how are you checking for spark? Plugging the spark plugs into the cables and laying them against the rocker cover won't work on these engines because the rocker covers are insulated from ground by the rubber seals...
Sidecar Bob's illustration shows the neutral diode's function very well: isolates the neutral switch ground path of the starter solenoid from the clutch switch ground path. If it wasn't in there, the neutral lamp would light every time you pulled the clutch. Which come to think of it, would be an easy way to check for a shorted diode.
The light coming on when you pull the clutch lever is a classic sign of a shorted diode.
Diodes can also fail in open circuit mode; When that happens it won't start in neutral unless you squeeze the clutch lever.
But neither of those failure modes would prevent the spark from occurring.
- Cakey
So I’m lost.
Power to red wire on Dyna
Bypassed the ballast resistor by joining the wires
Replaced the diode
I have connected the plug with alligator clips to earth and no spark at all.
I did replace my handgrips, and was wondering if this could do something to the kill switch. Is there a way to check of the kill switch is stuck on? Any help appreciated
Replaced the diode
1975 Gl1000
The kill switch disconnects the coils from power. You should have voltage on the black/white wire at the coils when the kill switch is set to Run.
- Cakey
So turn power on, set kill switch to run and check for power at the black and white wire to coil?Sidecar Bob wrote: ↑Thu Jul 01, 2021 10:47 pm The kill switch disconnects the coils from power. You should have voltage on the black/white wire at the coils when the kill switch is set to Run.
1975 Gl1000
- Cakey
I’ve got no power to the black and white wire in any of the positions. Can I bypass it to get it running?
1975 Gl1000
You could connect a temporary jumper between the black/white and a black wire but I would only do that as a last resort.
Are you sure that the wires that previously connected to the ends of the resistor are solidly connected to each other? The solid black one is switched power (live when the key is ON) and the one with the stripe takes power to the kill switch so if they aren't connected well that could prevent power from getting to the kill switch.
- 13 Replies
- 789 Views
Last post by Stealth126
- 25 Replies
- 948 Views
Last post by terry_208
- 58 Replies
- 890 Views
Last post by NCScooter
- 13 Replies
- 407 Views
Last post by ankof
- 8 Replies
- 412 Views
Last post by robin1731
