1200 Standard not starting and Backfire…
- heath1066
- Zinc Member
So. I replaced my coils with Dynas a month ago. Been riding daily no issues. Parked last Sunday night, didn’t go anywhere til Wednesday and bike wouldn’t start, really wanted to, but then 1/3 side backfired. Like not a deceleration, not starting little backfire, like a call the cops someone has 1/4 sticks and is setting them off in the alley kinda backfire. So I let it rest and took the Jeep instead… today I checked my plug wires, plugs, coil wires, etc… still did the same. Before I go checking timing belts for spontaneous failure… anyone have any ideas?
Heath Hays
Chicago, IL
Chicago, IL
Re: 1200 Standard not starting and Backfire…
A really loud backfire is often a spark way out of time, or on our bikes, the “waste spark” can light of a mixture that didn’t get lit on the compression stroke into the exhaust on the exhaust stroke.
A cheap check for hints is to check your plugs, oily?
Wet?
It’s not likely your timing moved, but with new coils, it could be a pulse generator or spark unit. (Can’t recall 84 for sure)
Wet?
Definitely want to check the belts and cam timing. I am not familiar with the advance on the 1200 but believe it is vacuum activated. I wonder if it could be stuck?
- heath1066
- Zinc Member
Belt are three years old, but I never thought to check the vacuum advance, if the rain breaks this afternoon I’ll check that out…
Heath Hays
Chicago, IL
Chicago, IL
I am not at all familiar with a 1200.
Are your spark plug wires reversable?
Like 1 and 3 could be reversed.
That will make a big bang!
Cliff (74yrs )
- heath1066
- Zinc Member
You can reverse them but they are correct, and the bike was running fine with no changes a few days before…
Heath Hays
Chicago, IL
Chicago, IL
Some early 1200 manuals actually had the firing order wrong.
You mentioned rain. Any chance sme water might have gotten in the spark plug well's? If the drain holes are plugged the water and spark can do strange things
A backfire in the exhaust can be caused by an intermittent fault somewhere in the primary ignition circuit. Since it won’t start at all now the fault may not be intermittent anymore. Check everything. Ignition switch, kill switch, all wiring connections.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
Have you/do you regularly use the off/run/off handlebar switch?MikeNTexas wrote: ↑Sun Jul 11, 2021 8:43 pm A backfire on the exhaust can be caused by an intermittent fault somewhere in the primary ignition circuit. Since it won’t start at all now the fault may not be intermittent anymore. Check everything. Ignition switch, kill switch, all wiring connections.
Cliff (74yrs )
- heath1066
- Zinc Member
The bike has been rewired with an m-unit so the handlebar kill is no longer used period. Water is a slight poss, it’s been raining forever..and still is this afternoon…
Heath Hays
Chicago, IL
Chicago, IL
- heath1066
- Zinc Member
Alright issue resolved! Two bad spark plugs, one real bad and one weird and intermittent. After rechecking and testing all wiring, testing the ignition unit Vac advance with a syringe, and further checking the 6v circuit fully, I pulled the plugs again and cleaned and gapped, put them back the the misfire switched sides. After testing spark plugs found one bad one and one questionable, so they all got replaced and she fired in the first push of the button. Plugs are only 3 years old, but I know the resistor caps were several times that age at least…
Heath Hays
Chicago, IL
Chicago, IL
- ritalz
- 6 Replies
- 603 Views
Last post by CYBORG
- 14 Replies
- 833 Views
Last post by heath1066
- 14 Replies
- 1792 Views
Last post by desertrefugee
- 21 Replies
- 2039 Views
Last post by VintageGW's
