Rear Signal Stem Size?
- Dr. Frankenstein
Does anybody know what size the rear signal stems are for a '78 GL1000? It looks like a pretty big hole - 12 or 13 mm - but I also can't determine the pitch; is there a source for these stems anywhere? Is there another bike that uses the same size?
Re: Rear Signal Stem Size?
1983 GL1100A Aspencade
1977 GL1000
1978 GL1000
1979 GL1000
“I see Angels on Ariels in leather and chrome,
Swoopin' down from Heaven to carry me home."
1977 GL1000
1978 GL1000
1979 GL1000
- Jonesz
Those do not fit a 78 as the turn signals are mounted to the tail light rather than the grab rail and the size is different. Before ordering them I contacted saber cycle and was assured they were correct. They are not. Had to have special adapters machined to accept them. Sorry remember the correct size but it seems to me they were 14mm on my 78.MattMcCoy wrote: ↑Mon Sep 27, 2021 9:53 am Here you go:
https://www.google.com/amp/s/www.saber- ... %3Famp%3D1
Jonesz
1979 Suzuki GS850. Sold
Thanks for the info.Jonesz wrote: ↑Mon Sep 27, 2021 11:06 amThose do not fit a 78 as the turn signals are mounted to the tail light rather than the grab rail and the size is different. Before ordering them I contacted saber cycle and was assured they were correct. They are not. Had to have special adapters machined to accept them. Sorry remember the correct size but it seems to me they were 14mm on my 78.MattMcCoy wrote: ↑Mon Sep 27, 2021 9:53 am Here you go:
1977 GL1000
1978 GL1000
1979 GL1000
1977 GL1000
1978 GL1000
1979 GL1000
- Dr. Frankenstein
Yes, it's true - Jonesz is accurate; I did get some for my '75, and the front ones screwed right in, but I had to drill out and tap the rear mount that I had to take the 10mm light mount.
If anybody here has a lathe, that would make a nice little side-gig - making adapters for the early models.
- BlueThunder
Any change in Saber Cycle's reputation??
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
I bought a set of these (no affiliation or knowledge of seller) https://www.motorcycleid.com/ks-technol ... -1217.html that were way too small for my 78 tail lamp setup, if the earlier ones take a smaller size they may fit.
I had a heck of a time finding some that were larger and correct, and the chrome was shot when I did find them so I'm technically still looking for some..
- BlueThunder
If you don't mind reproductions, check 4-into-1.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
4n1 looks to have the short ones but not the long for the rear on a 78, and some of the smaller diameter thread size ones.
- 11 Replies
- 348 Views
Last post by Sidecar Bob
- 382 Views
Last post by Don R
- 48 Replies
- 2125 Views
Last post by Dr. Frankenstein
- 4 Replies
- 140 Views
Last post by Wetduck
