A while back HF used to give away their little red VOMs with any purchase. I amassed enough of these to stick one in each vehicle and two more in my garage. The meters are actually pretty good and are very handy for diagnosing automotive electrical problems. But the probes that come with the meter are junk and threaten to make the meter unusable. So I went to Vetco Electronics, a cool store not too far from where I live, to see if they had anything I could use to cobble some decent probe leads. But lucky enough, no cobbling necessary. I bought a couple of these lead sets to give them a try:
https://vetco.net/products/shrouded-ban ... e-leads-36
I had to cut 3/8" of the shrouds that cover the banana plugs so they would insert far enough into the meter and they work like a charm. Can't attest to their longevity of course but they appear to be fairly beefy and well made. Vetco tends to carry pretty good stuff.
Harbor Freight VOM resurrection
- tlbranth
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: Harbor Freight VOM resurrection
Paying more for the replacement leads than the meter sold retail for sounds wrong, but that said I have several of those meters and am considering the same fix. But also, remember to change the batteries yearly to avoid leakage damage, and maybe even keeping the batteries ready but not installed for meters left in a trunk/glovebox/tool tray, etc.
I was just using one of those to check a crank positioning sensor. It was giving a out of spec reading so I double checked with my snap on and the cps was in fact in spec. I imagine with all things chinese accurate function is hit or miss. Just my experience.
1981 Goldwing GL1100
Microsquirt efi
Microsquirt efi
- tlbranth
Good call on the battery check. I've ruined more gadgets by not doing that.pidjones wrote: ↑Fri Oct 01, 2021 8:05 am Paying more for the replacement leads than the meter sold retail for sounds wrong, but that said I have several of those meters and am considering the same fix. But also, remember to change the batteries yearly to avoid leakage damage, and maybe even keeping the batteries ready but not installed for meters left in a trunk/glovebox/tool tray, etc.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
FWIW, similar leads are available on eBay for about $2 US (search multimeter leads with the order set to Price + shipping, lowest first), I don't know whether they are the same quality but if you only use them occasionally thy would probably be good enough.
Could very well be the leads... topic of this thread.
Possibly. Definitely worth testing against a known good meter so as to not be replacing a good part for no reason.
Microsquirt efi
Microsquirt efi
