Caliper mount touching disc
tallnwise
Re: Caliper mount touching disc
Post by tallnwise »
OK -- so got time to pick this up again -- everything seemed there in the correct order of assembly:
Before:
Taken apart:
Also, before removing the axle I had turned the rear wheel -- it was not scraping all the way around -- it scraped for half a turn, was free for half a turn, and so on. To my eye, did not look like the disc was warped.
Is the disc the issue?
Thanks,
Dan.
1980 GL 1100
If the brake disc is only scraping in one area, one would assume the disc is warped or the wheel is not running true.
A few thoughts... there is a "collar" about three inches long that should be located inside the final drive which the axle inserts into (between the wheel and final drive). It can be easily misplaced...
It may have been mentioned before, but the proper procedure for installing/ tightening the wheel/ final drive should be followed to ensure correct alignment.
tallnwise
Post by tallnwise »
OK -- so did a quick fix. I placed a 7/8 diameter thin bushing on the inside of caliper bracket between that and the inner spacer that goes into the wheel. No more scraping
I do have new disc I will install in spring when I replace my tire and also my bearings.
Thanks everyone for helping with this.
Best regards,
Dan.
1980 GL 1100
MikeNTexas
Post by MikeNTexas »
Is the long spacer in place that slides into the final drive?
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
tallnwise
#20
Post by tallnwise »
Are you referring to #16? Or something else?
10-17-2021 5-10-10 PM.png (190.83 KiB) Viewed 97 times
Thanks,
Dan,
1980 GL 1100
MikeNTexas
#21
tallnwise wrote: Sun Oct 17, 2021 5:11 pm Are you referring to #16? Or something else?
Thanks,
Dan,
Yes
tallnwise
#22
Post by tallnwise »
kewl, thanks. Pretty sure it is there, will check it out.
1980 GL 1100
