If you only need it occasionally for starting when it is punishing you for neglecting it too long it seems to me that a primer bulb would be the easiest solution
Electric Fuel Pump Suggestions
Re: Electric Fuel Pump Suggestions
I'm going to give some thought to the primer bulb suggestion. I like the fact it is low tech and no wiring is involved!Sidecar Bob wrote: ↑Tue Oct 19, 2021 1:09 pmIf you only need it occasionally for starting when it is punishing you for neglecting it too long it seems to me that a primer bulb would be the easiest solution
Thank you all for the suggestions!
-P.
If you’ll keep the tank topped off the fuel will gravity feed to the carbs. Turn the gas on and let it set for a few minutes and it should start right up.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
- 10 Replies
- 870 Views
Last post by OCR
- 8 Replies
- 662 Views
Last post by boogie red
- 554 Views
Last post by Rat
- 3 Replies
- 492 Views
Last post by Gowing
