New tires with vintage looking tread?
- Zinc Member
I've been looking for a set of tires for my GL1000 1976. Would like to get tires with a more vintage look, but of course modern performance. There are several makes such as shinko, avon, continental, etc. Problem is I've been unable to find a matching front/rear set with the specs for the bike. The rear seems particularly difficult to find (130/90 x 17). Wondering if someone else has gone through the same turmoil and found a solution?
1975 GL1000, on the road but patiently awaiting restoration
1976 GL1000, in the middle of a frame-off restoration.
Re: New tires with vintage looking tread?
Here is a good article.
https://www.randakksblog.com/tire-recommendations/
I like the Shinko 230 tires and also use the Shinko 712 tires. Continental still makes the vintage front with the ribbed look, but they don't make the 4.50-17 for the rear. I have used Bridgestone Spitfire tires and they are nice, but pricey. Get a set of the Shinko 230 tires and you will be happy.
- Lucien Harpress
I'm currently running Shinko Tourmasters on my '76, and I think that's about as vintage as you're going to get (with the added benefit of being rather affordable). Dunlop 404s are another popular choice, but I have no idea of the size availability of those.
Another thing to think about- mixing and matching tread patterns is a topic that usually inspires some spirited debate, but a lot of bikes of similar vintage (looking at you, CB750) liked to run a straight ribbed front tire with a more aggressive tread on the rear. Again, have no idea what's available in GL1000 sizes and take what you will from other people's opinion on tires (sorry, puppies), but that's the advice I have to give.
If you want modern performance, you will have to go with modern tread patterns. Having ridden on the old bikes in the '70s, I sure don't want to go back to their short life, poor cornering, sketchy braking. If it is just a show bike, go for appearance retro like Coker.
Yea I ran the IRC's for several years then the Dunflop 404's. Once I switched the higher grade Metzlers I would never go back. The life and stability difference is considerable.
I wouldn’t run the ribbed OE front ! If you’ve never ridden on the ribbed front you’ll find that the ribbed front tires tend to follow any grooves in the pavement causing the bike to wander uncontrollably. Rain grooves are really a pucker event, I won’t use them !
I'm a real outlaw, Michelin Pilots.
- Zinc Member
A lot of suggestions! Thanks everyone. I'll continue my research.
- 13 Replies
- 662 Views
Last post by deathbypizza
- 13 Replies
- 328 Views
Last post by rcmatt007
- 11 Replies
- 214 Views
Last post by John Schmidt
- 19 Replies
- 1236 Views
Last post by Rednaxs60
