cylinder 3+4 not firing
- pierce
- My Album: pierce
Before I get any further, I'm running an 86 engine with CDI (black box) in my 76.
My problem is that it is only running on cylinders 1+2.
I am aware that the right coil fires cylinders 1+2, so I replaced my coils with dyna. Much better spark, but still nothing. So I then replaced the black box. Still nothing on 3+4.
Looking for more input from wing gurus to solve the issue.
Ordered pulse generator (luckily they are in the front on an 86), but if that doesn't work I'm all out of ideas.
Anyone have any input or am I missing anything?
My bike has been running perfect until the other day when it just died and I couldn't get it started.
Thanks in advance!
Thanks in advance!
1976 GL1000
1978 Gl1000
1978 Gl1000
Re: cylinder 3+4 not firing
So, you are saying you don’t have any spark on 3-4? I would see what the new pulse generator does for you.
- pierce
- My Album: pierce
Thanks so much for the reply.
Yes, no spark at all. I can get it to run roughly. When I pull either of the front plugs I can visibly see a very strong spark and it struggles to stay running. When I pull either of the rear plugs, nothing.
1976 GL1000
1978 Gl1000
1978 Gl1000
I would replace the pulse generators…seems to me there was one for each bank.
Possibly the pulse generator has moved too far to function? I think there are two bolts holding each one. 0.16” to 0.040” air gap for the 84 model which is the manual I have. You’ll find out when me pulse generator comes. Not much room with the radiator in there, but pull the covers and you could probably see each one. There is also a bracket which holds the wire loom against the motor which if loose would allow the wires to contact the belts or crank pulley.
I bought PGs from Honda a couple of years ago for an 85, which has them on the front. They come as an assembly for both sides. There's no adjustment--tighten the mounting bolts, run the wires, and they're installed.
BTW, the signal for the tach comes off the trigger for the 1/2 coil, and the fuel pump relay trigger is off the 3/4 set. Have you noticed if either of those is flaky?
- pierce
- My Album: pierce
Unfortunate, or fortunate, I'm running the motor on a 76. This means it's not connected to either the fuel pump or tachometer. In fact, I just deleted the tach.Shadowjack wrote: ↑Thu Oct 14, 2021 8:38 am I bought PGs from Honda a couple of years ago for an 85, which has them on the front. They come as an assembly for both sides. There's no adjustment--tighten the mounting bolts, run the wires, and they're installed.
1976 GL1000
1978 Gl1000
1978 Gl1000
- pierce
- My Album: pierce
Installed new pulse generator. It did nothing.
Front two wires are firing, but rear two have no spark.
I tested each connection going to the coil and I get full voltage, 12/13 with ignition on, and 14 when running. Same with both coils.
Any ideas what to look for now?
1976 GL1000
1978 Gl1000
1978 Gl1000
- BlueThunder
Have you done the obvious? Replaced spark wires? Caps? Plugs? Made sure coil wires were getting power? Made sure no grounding issues with coil/pulser for 3/4?
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- pierce
- My Album: pierce
Figured it out. One small bit of wiring went bad. I put in some new wire, and all cylinders are firing.
and here are some sexy pics of my new seat:
- 20211026_120107.jpg (128.35 KiB) Viewed 193 times
1976 GL1000
1978 Gl1000
1978 Gl1000
- RIP: cookie
I think I’ve bought bikes for less than that seat cost ...
Gord(but they are the best)Jones
Where was the bad wire? Glad you found the issue, but also sorry you had to throw some parts at it.
- pierce
- My Album: pierce
- pierce
- My Album: pierce
This wire was coming out of the black box(cdi) and feeds into the left coil.
When I converted the 1000 to use the 1200 black box I had to rewrite the coils.
1976 GL1000
1978 Gl1000
1978 Gl1000
- 12 Replies
- 440 Views
Last post by NotSoLilCrippseys
- 14 Replies
- 655 Views
Last post by gltriker
- 13 Replies
- 274 Views
- 50 Replies
- 967 Views
Last post by quarefish
- 21 Replies
- 520 Views
