75 GL1000 cable grommet
- Tin Member
This might be a stupid question, but is there really such a thing? Giving my ntm 75 a good deep cleaning since I've got it completly disassembled due to a frame replacement. Working on cleaning some rubber parts on front end. What can i use to brighten up my fender cable grommet? I'm sure it wasn't snow white new, but sure I can do something. Long winded ?, but soap and water not doing it. Fingernail did leave a mark. Any tricks?
- 20211024_222808.jpg (99.63 KiB) Viewed 206 times
Re: 75 GL1000 cable grommet
Originally black. You might try a soak in your favorite rubber restorer. Sun and years have done their damage.
- Lucien Harpress
Alternately, quite a few Honda bikes used that same part, so a nicer replacement might not be that hard to get a hold of.
FWIW, Honda had those in both black and a pale gray and probably used the black and gray versions on different models.
As I've often said, 4 decades is a long time so it is not surprising to find parts from other models on a bike that old.
Here's a pic of the gray version
https://www.cmsnl.com/products/grommetwire_45451283000/
- Tin Member
Hah, would have never guessed black or gray. But as I look closer at mine could see a gray possibility. Just so happens I did order a new Honda black on an order as I figured my original would fall apart on removal. Thanks folks and another ? about original hose clamp and wire guard color coming next!
Try Scotchbriting that one to see if it cleans up.
- Tin Member
I'll give that a try Shadowjack. Maybe I'll switch from off white to black occasionally. Mix it up lol.
- 8 Replies
- 298 Views
Last post by pidjones
- 187 Views
Last post by RB
- 774 Views
Last post by Sidecar Bob
